Hardware: Cubox-i2ultra
Issue: built in wifi chip has really poor performances!
Dongle used: Asus usb N13 Rev B1 (RTL8192CU chipset)
Dongle works very good with Archlinux (archphile 0.99.1 cubox), using drivers from manufacturer instead of the drivers included in the kernel (dongle is as bad as the internal one using kernel provided rtl8182cu drivers)
Manufacturer drivers cannot be compiled without kernel-headers (and I do not manage to get the correct headers for cubox-i).
Could the realtek drivers be included in next Volumio release, instead of the ones currently available out of the box (may be moved to “suggest a feature” panel)?
I try to use the CSL 300 mbit/s dongle with external antenna.
It is powered bei Realtek RTL8191SU chip but shows very strange behaviour:
The dongle detects all available networks but does not connect. even on different hardware: Rpi 2 + RPi3, with or without AMP-Boards. And most Exiting: the same hardware configuration runs smoothly with other operating systems: Raspbian, max2play and some others.
I already updated the realtek firmare to the lastest version-without success.
