Hi all,
my family is a heavy Spotify user, therefore the whole Spotify experience is important to us.
My main use cases for Spoitify are
- Select & play Spotify albums on Volumio
- Hand off Spotify to another device
- Hand Spotify to Volumio from another device
I tried the “official” Spotify 2.0.2 plugin which enables local playback, but I can not see it as device in the regular Spotify app. Pulling a stream from Volumio to Alexa Echo is not possible. I also tested Volumio Spotify Connect2 0.9.9, but I kind of don’t see any change in Volumio, it does not show up in my Spotify app as device. I also installed latest version from Github, no difference.
I thought with installing both plugins I get best of both worlds and I could satisfy my use cases. Is that possible?
Regards
bluepuma
