Hi all,
Im trying to update a retro radio setup i did a little while ago… because i know it could be better
This is my raspberry pi set up at the moment and the first thing i need some advice on are the following questions.
- Should i upgrade the pi to a 5? (Or 4)
- Should i change the amp zero to a different hat?
Hopefully the next pic will help with the next questions
This is the space i am working with, rough estimation of free space is. L 4" W 8" D 2"
It leads me to my final question, this was the old speaker and i am useless at this bit
- Can you recommend a 5 inch mono speaker that would work with the existing (or recommended improvements from initial questions, both preferably) hardware.
I would be delighted to add a new 5inch speaker and get much improved sound quality.
Thanks so much for reading this, appreciate any help
