Which dac analog or digital?
I’m buying a new amp (AUDIOLAB 6000a) with an internal DAC.
Which kind of DAC for raspberry do you recommend? I can use digital or analog with the new amp, there are some differences regarding the audio quality?
Candidates:
For the digital version:
HIFIBerry DIGI+ PRO
ALLO DigiOne
For the analog version:
HIFIBerry DAC 2 HD
ALLO the Boss
Do you have other pi hat to suggest?
P.s. I have a flac archive to reproduce.
Hello
I use the Allo Boss and I am extremely satisfied.
I also recommend using ultra low noise power supplies. e.g. ifi-Audio iPower.
There are also very low-noise power supplies from Allo, but I cannot report any experience.
regards
rost21A
Thank you!
i will take a look. Without a low noise power supplies, the noise are too much?
That depends on your requirements.
I like it better with an ultra low-noise power supply. More fine details, better spatiality, with live recordings, better atmosphere, the voices are more real, etc.
Simply much more real and better.
regards
rost21A
The Audiolab 6000a is a well reviewed amp and the integrated ESS9018 dac chip is a good circuit (it still needs a good implementation by audiolab to make it work well and I haven’t seen a review where this has been properly evaluated). If the ESS9018 has been well integrated in the amplifier it is unlikely that a Raspberry PI HAT dac will beat it and the digital solution you propose is probably best with less susceptibility to digital noise etc.
