I am starting to get more organised with my code and am now creating my own node.js modules to compartmentalise the bits of code I’m writing.
The question I have now is, what is the best way to pull in a node module I’ve written myself (and is stored on github) so that it’s usable by a plugin?
I know I can use package.json to pull in a github repository, and then use npm install to install it, but I can’t figure out where this actually goes on the system - it doesn’t seem to appear in volumio/node_modules
To be clear - these modules aren’t plugins. They are modules that I want my plugins to reference.
I do need to find out where it’s being installed so I can set some environmental things within it.
I can’t see the answer to my question there though - that page you posted is generally about plugins and how they work. I couldn’t see anything about where to put other modules (that aren’t plugins)
