Where are the images?
I just signed up for MyVolumio and perused the page of info and links. NOT in that list, as far as I can see, is a way to download the image file for the premium service. Can you please direct me to how you get this image file since it seems to kind of important, or explain how to use MyVolumio with the image I already have? Is it is hiding?
Thanks,
Steve
Hi Steve,
myVolumio is integrated in the image you already have. Just make sure you login (you will see the login in the settings menu). You will find all info in the sources page then.
Let us know
Thanks very much for your reply. I was easily able to login on my current image. I don’t where I read that it was a separate image, but anyhow it’s working great with Tidal right now.
Thanks,
Steve
