When stopping mother earth and not playing anything after a while the green light lit and it is impossible to connect to Volumio
Continuing the discussion from [Plugin] Mother Earth Radio 1.0.0:
Hello
I have installed the plugin Mother Earth Radio 1.2.2 on Rasbery pi B3+.
It works fine BUT…
When stopping mother earth and not playing anything after a while the green light lit and it is impossible to connect to Volumio. I tried IP/dev but nothing. the only solution is to unplug and plug again.
Do you have an idea ?
Here is the log when launching Mother Earth
info: CALLMETHOD: system_controller system setTestPlugins true
info: CoreCommandRouter::executeOnPlugin: system , setTestPlugins
info: Plugins store is now in test mode
info: Preload queue cleared
info: CoreCommandRouter::volumioReplaceandPlayItems
info: CoreStateMachine::ClearQueue
info: CoreStateMachine::stop
info: CoreStateMachine::stPlaybackTimer
info: CoreStateMachine::updateTrackBlock
info: CorePlayQueue::getTrackBlock
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
info: [1731588667437] ControllerWebradio::stop
info: CorePlayQueue::clearPlayQueue
info: CorePlayQueue::saveQueue
info: CoreCommandRouter::volumioPushQueue
info: CoreStateMachine::addQueueItems
info: CorePlayQueue::addQueueItems
info: Adding Item to queue: webmer/0
info: Using cached record of: webmer/0
info: CoreCommandRouter::volumioPlay
info: CoreStateMachine::play index 0
info: CoreStateMachine::play index undefined
info: CoreStateMachine::startPlaybackTimer
SPOTIFY: RECEIVED VOLUMIO VOLUME 0
info:
---------------------------- MPD announces state update: player
info: sendMpdCommand stop took 40 milliseconds
info: ControllerMpd::getState
info: sendMpdCommand stop took 10 milliseconds
info:
info:
info:
info:
---------------------------- MPD announces system playlist update
info: Ignoring MPD Status Update
info: sendMpdCommand status took 14 milliseconds
info: sendMpdCommand clear took 12 milliseconds
info: sendMpdCommand status took 11 milliseconds
info: sendMpdCommand status took 8 milliseconds
info: sendMpdCommand status took 6 milliseconds
info: ControllerMpd::pushState
info: Received update from a service different from the one supposed to be playing music. Skipping notification.Current motherearthradio Received mpd
info: ------------------------------ 63ms
info: ------------------------------ 61ms
info: ------------------------------ 59ms
info:
info:
info:
error: updateQueue error: null
info: ------------------------------ 67ms
info: sendMpdCommand playlistinfo took 63 milliseconds
info: sendMpdCommand consume 1 took 63 milliseconds
info: ------------------------------ 13ms
info: ------------------------------ 11ms
info: ------------------------------ 9ms
info: [1731588667564] [MotherEarth] set to consume mode, adding url: https://motherearth.streamserver24.com/listen/motherearth/motherearth
error: ControllerMpd::pushError: TypeError: Cannot read property 'split' of undefined
info: ------------------------------ 89ms
info:
info: sendMpdCommand add "https://motherearth.streamserver24.com/listen/motherearth/motherearth" took 12 milliseconds
info:
info:
info:
info: ------------------------------ 24ms
info: sendMpdCommand play took 8 milliseconds
info: ------------------------------ 6ms
info: ------------------------------ 5ms
info: ------------------------------ 3ms
info:
info:
info:
info:
info: FusionDsp -  ---- read samplerate, raw: 192000,S32_LE,2,32
info: FusionDsp -  ---- read samplerate from file: 192000
info: camilladsp stopping service pid 16000...
i-sabre-codec-i2c 1-0048: ASoC: error at snd_soc_component_update_bits on i-sabre-codec-i2c.1-0048 for register: [0x00000021] -121
info: camilladsp service terminated, instance 1
info: FusionDsp -  If filter freq >samplerate/2 then disable it
info: camilladsp service started and running in background, instance 1
info:
info: sendMpdCommand status took 51 milliseconds
info: sendMpdCommand status took 50 milliseconds
info: sendMpdCommand status took 48 milliseconds
info: sendMpdCommand status took 46 milliseconds
info:
info:
info:
info: sendMpdCommand playlistinfo took 47 milliseconds
info: sendMpdCommand playlistinfo took 46 milliseconds
info: sendMpdCommand status took 44 milliseconds
info: sendMpdCommand status took 43 milliseconds
info: sendMpdCommand status took 42 milliseconds
info: ------------------------------ 111ms
info: ------------------------------ 109ms
info: ------------------------------ 107ms
info: ------------------------------ 106ms
info: camilladsp spawned new process with pid 16058, instance 1, run: true
info: sendMpdCommand playlistinfo took 31 milliseconds
info: sendMpdCommand playlistinfo took 30 milliseconds
info: ------------------------------ 92ms
info: ------------------------------ 86ms
info: ------------------------------ 84ms
info: ------------------------------ 83ms
info: CoreStateMachine::syncState   stateService play
info: CoreStateMachine::syncState   currentStatus stop
info: [1731588667885] [MotherEarth] setting new timer with duration of 132000 seconds.
info: Prefetching next song
info:
info:
info:
info:
info:
info:
info:
info:
info: ------------------------------ 23ms
info: sendMpdCommand status took 18 milliseconds
info: ------------------------------ 18ms
info: sendMpdCommand status took 20 milliseconds
info: ------------------------------ 19ms
info: sendMpdCommand status took 15 milliseconds
info: ------------------------------ 15ms
info: sendMpdCommand playlistinfo took 4 milliseconds
info: ------------------------------ 40ms
info: ------------------------------ 34ms
info: ------------------------------ 31ms
info: ------------------------------ 25ms
info: CoreStateMachine::syncState   currentStatus play
info: Received an update from plugin. extracting info from payload
info: [1731588800225] [MotherEarth] setting new timer with duration of 240000 seconds.
info: CorePlayQueue::getQueue
info: [1731589040519] [MotherEarth] setting new timer with duration of 175000 seconds.
please provide a full log when it happens, partial copying it doesn’t help us.
from the log you provided i can see that a possible issue might be the timer duration that the plugin sets:
that doesnt look correct. but the logs also say that we are playing at this moment (if i read it correctly). so, you started playback, then stopped, then volumio crashed? what is this log then? did you reboot, then started playback and this is the log we see?
thanks for clarifying, i will try and reproduce myself.
Hello
Thanks for your answer.
Process : I start volumio, Choose Mother earth radio, play few minutes, stop Mother earth… wait around 20 minutes then it is impossible to access Volumio and the green led of my raspberry is on .
The only solution is to unplug the raspberry
I am using the plugin
Here is the full log until it crashes. I am using also Camilla DSP with some filters and Resample ( for other radios )
Starting Live Log...
No alpha test mode
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateEnabled
info: Update Ready: {"changeLogLink":"http://volumio.org","description":"
FIXES
        Improved translations
        Fix Multiroom Buffer Sizes
        Increase results for Kana-Kanji Conversion
        Fix for streaming interruptions
NEW ADDITIONS
        Bump RPi kernel to 6.6.56, support for RPi5 2GB
        Dedicated entry for RPi5 on some I2S DACs, restored master mode for older RPi models
        Add support for HifiBerry AMP4 Pro on RPi
","title":"Update v3.779","updateavailable":true}
info: CoreCommandRouter::executeOnPlugin: updater_comm , setUpdateMessageCache
info: CALLMETHOD: system_controller my_volumio retreiveBackendEventStates undefined
info: CoreCommandRouter::executeOnPlugin: my_volumio , retreiveBackendEventStates
info: Received Get System Version
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: metavolumio , getInfinityPlayback
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
info: FusionDsp -  IP adress is ---------------------------192.168.1.122
info: CALLMETHOD: system_controller system setTestSystem true
info: CoreCommandRouter::executeOnPlugin: system , setTestSystem
info: CoreCommandRouter::executeOnPlugin: updater_comm , checkUpdates
info: Device is now in test mode
Test mode enabled
No alpha test mode
FIXES
NEW ADDITIONS
Test mode enabled
No alpha test mode
FIXES
NEW ADDITIONS
info: [1731664707443] [MotherEarth] setting new timer with duration of 338000 seconds.
82.67.41.119 local addr 192.168.1.122 ->
185.123.84.51 local addr 192.168.1.122 ->
82.64.247.11 local addr 192.168.1.122 ->
95.179.212.126 local addr 192.168.1.122 ->
193.52.136.2 local addr 192.168.1.122 ->
info: [1731665045789] [MotherEarth] setting new timer with duration of 10000 seconds.
5.196.160.139 local addr 192.168.1.122 ->
51.68.180.114 local addr 192.168.1.122 ->
51.15.191.239 local addr 192.168.1.122 ->
info: [1731665056073] [MotherEarth] setting new timer with duration of 223000 seconds.
5.39.80.51 local addr 192.168.1.122 ->
info: CoreCommandRouter::volumioPause
info: CoreStateMachine::pause
info: CoreStateMachine::servicePause
info: CoreCommandRouter::servicePause
info:
info: sendMpdCommand pause took 3 milliseconds
info: CoreStateMachine::syncState   stateService pause
info: CoreStateMachine::syncState   currentStatus pause
info: sendMpdCommand status took 23 milliseconds
info:
info:
info:
info: sendMpdCommand playlistinfo took 23 milliseconds
info: sendMpdCommand status took 21 milliseconds
info: sendMpdCommand status took 12 milliseconds
info: ------------------------------ 58ms
info: sendMpdCommand playlistinfo took 5 milliseconds
info: sendMpdCommand playlistinfo took 6 milliseconds
info: ------------------------------ 36ms
info: ------------------------------ 26ms
info: camilladsp spawned new process with pid 3353, instance 1, run: true
212.85.158.10 local addr 192.168.1.122 ->
Starting Cleanup of Temporary Directories...
systemd-tmpfiles-clean.service: Succeeded.
Started Cleanup of Temporary Directories.
error: [yt-cast-receiver] RPC connection reader error:
(Error) Premature close
Error: Premature close
    at IncomingMessage. (/data/plugins/music_service/ytcr/node_modules/node-fetch/lib/index.js:1749:18)
    at Object.onceWrapper (events.js:421:28)
    at IncomingMessage.emit (events.js:315:20)
    at TLSSocket.socketCloseListener (_http_client.js:435:11)
    at TLSSocket.emit (events.js:327:22)
    at net.js:673:12
    at TCP.done (_tls_wrap.js:563:7)
    at net.js:673:12
I did some test and it is clearly related with the plugin Fusion DSP.
When it is off o have no problem.
Please send a link for the log, not just a live log. TY
Hello Balduze,
Please find the link to the log
http://logs.volumio.org/volumio/6ogv8VU.html
