I’m an happy owner of a Raspberry PI 3B+ which I bought from Volumio shop when they were selling them. It is connected to a vintage Mission Cyrus I and speakers Mission 781, both bought in 1994.
After missing the community for some time (but still enjoying Volumio on my audio system) I came back to see the news also because a friend of mine is interested in getting something similar to what I have.
What could be a good configuration without spending a fortune nowadays?
I have heard that with the new Raspberry PI 4 the I2S hat is not anymore a good option but it’s better to have an external USB DAC. Apparently one of the best is the Topping E30. Are there others?
And why someone is suggesting to use a hat to connect the USB DAC? Can you explain me what is the advantage?
From what I understand the USB bus is compromised on the rpi 2/3, due to sharing lanes with the ethernet. Thus it is not able to handle high quality bitrates sustained. This is not an issue with the RPi4.
If you want to use an external DAC (and it seems the sky is the limit here in terms of price), then you can either go with an RPI4 and use the USB to connect, or use a digital-output HAT (either RPI 2/3 or 4). Theres a range of options and pricepoints here too. The connections will either be SPDIF (coax / optical) or I2S (over HDMI or RJ45 connectors). The higher end external DACs seem to be supporting I2S natively now (Topping DX7-Pro, D90… PS Audio etc), PS Audio championed I2S over HDMI cables in recent years, but there isnt really a standard for it.
I went with the Schiit Audio modi 3+ for now, which is in the same league/pricepoint as the E30. I’ve had my eye on the Denafrips Ares2, which is supposed to be amazing, but decided to wait a bit for that upgrade… it seems DACs can be quite the rabbit-hole… Schiit Audio: Audio Products Designed and Built in California
I just upgraded to Digione sig on a pi3B+ (Volumio, SW Version 3.067), with my Denefrips Ares II. Better, noticeable channel separation, wider sound stage and just cleaner sound. For the money ($750 USD); the Ares II gives me the sound I want. I also have a decent Parasound A23, and P3 preamp and KEF iQ9 speakers from 2006.
I tried to install volumio 2xx but with rasp 4 it is not compatible. so on the rpi4 I will unfortunately use an analgic dac which among other things stops working if I install peppy meter
hi
