What driver to use for that "custom" DAC
Hi there,
I’m working on a Raspberry Pi (B+) project that should output audio through an FM transmitter IC. Right now I’m using the analog input, but I’d like to switch over to I2S, as the transmitter IC features a “digital mode”.
The mentioned IC is a 4713 by Silicon Labs. Their datasheet gives a minimal example how to use the digital mode:
I left out the resistors and connected DCLK, DIN, DFS directly to the Raspberry PCM_CLK, PCM_DOUT, PCM_FS.
It’s unclear to me, how to output the I2S to the transmitter IC? Which driver to use? I’m running latest and up to date Rasbian image on the Pi. I tried to load drivers for the HifiBerry, etc. and thought the might work with my IC, too. — no result.
The datasheet (silabs.com/Support%20Documen … 13-B30.pdf, P.23) says not much about the digital mode — mainly:
— and:
Can someone push me in the right direction, what software/drivers I need to install/use? The described I2S mode in the datasheet — is it “standard” and compatible with the Raspberry, or some proprietary thingi?
Thanks in advance & Regards,
Hans
Hifiberry and generic should work without any changes
But for now I2S output doesnt work correctly on B+ … (some changes have to be made in the kernel)
Take a look at tjaekel website about that
Thank you so much — This information helps a lot! So i don’t have to try further for now… :slight_smile:
I think the model naming of the Raspberries is a bit problematic. There was the B in two revisions, and now there is the B+. This makes searching forums and the internet hard. I could not find clear information about I2S on the B+ in all places I looked for it.
Again — thank you! I’ll have a look at tjaekels site
Hi there — good news: my transmitter was playing I2s today!
Here is what I did:
  • Flashed SD card with newest raspbian image, 2014-09-09
  • To be save: rpi-update
  • Tweaked modules and rpi-blacklist files, created asound.conf
This is what my /etc/modules looks like
[code]#enable i2c
i2c-bcm2708
i2c-dev
disable analog audio
#snd-bcm2835
#enable dac+ hifiberry i2s output
snd_soc_core
snd_soc_bcm2708_i2s
bcm2708_dmaengine
snd_soc_pcm1794a
snd_soc_rpi_dac[/code]
This is my /etc/modprobe.d/raspi-blacklist.conf
blacklist spi-bcm2708 #blacklist i2c-bcm2708 #blacklist snd-soc-pcm512x #blacklist snd-soc-wm8804
Now I can play using aplay or mplayer. I just need to find out how to keep the PCM_DCLK and PCM_FS clocks up, when I don’t play any sound. My radio transmitter IC will leave I2S mode, when the clock signals are dead.
Thanks for your help!
