WebUI / First Run failure
Hi
Im trying to get Volumio to work and cant even get past the first step apparently.
Details:
Cubox i4 pro (new)
Downloaded VERSION: 1.2beta; flashed to SD Card (Sandisk ultra 16gb Cl10; new) successfully
Plugged cubox and laptop to router via Ethernet (plan on going wifi later)
Powered Cubox on; red indicator lights up fine
Here’s where im stuck - volumio.local/ wont even load
As mentioned, the red indicator is lit; the firmware appears to load. it also shows on my network as an unspecified device, but it wont load on the browser
what am i missing? thanks a ton for your help
Additional info:
After leaving it run for a while (connected the cubox to an HDMI monitor)
Volumio login: cat: /run/player_wrk.pld: No such file or directory
INIT: Id “TO” respawning too fast: disabled for 5 minutes
Will update for any changes
