WEBUI error
I want to know how i can restart webui interface with command like sudo service mpd restart.
I add a NAS mount and now i cannot to open sources.php or mpd-config.php or setting.php the screen show connecting and nothing happend …
I restart my Raspberry pi and i can go ONE time in sources.php for deleting my false nas config and when i apply nothing happend only connecting …
I think I can search the config file where NAS mount is save and i delete my false config but I don’t know where is it.
Any solution ?
Thanks for your Help
I give a solution here : https://volumio.org/forum/unable-add-modify-remove-mounts-using-webui-t2831-10.html:wink:
Thank you :smiley: :smiley: :smiley:
