Firstly (for Volumio developers) playing with the DAC settings to find the best tuning for my configuration, I’ve discovered that this cause a cosmetic, annoying bug where all tabs are renamed “COMMON.TAB_BROWSE”, “COMMON.TAB_PLAYBACK” etc. I’m using SAFARI 9.1.2. Is there a way to restore the correct tab localized strings without resetting the System?
However this happened while trying the best audio settings for my configuration:
Raspberry Pi2
DAC+ Pro
Volumio 0.976
If I select Hifiberry DAC and at the same time disable I2S DAC, I get a better sound quality? Please help me in understanding what I2S Dac function, thanks.
