jopreu
1
Volumio Version:2.779
Hardware: Raspberry 3+ and Hifiberry DAC
I want to add costom web radio stations. If I add:
https://unifm-streams.uni-freiburg.de/unifm.mp3
it won’t play. With the message:
Error
Failed to decode https://unifm-streams.uni-freiburg.de/unifm.mp3; CURL failed: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
However, in VLC media player or in a web browser (Firefox) it works.
What can I do?
jopreu
2
Different browsers say, that the certificate is ok.
Trying http instead of https doesn’t work here.
jopreu
3
I made it.
I downloaded the certificate with firefox by playing the webradio clicking on the lock symbol.
Then I followed these steps:
“Installing a CA” response by M. Haase
like this (I renamed the downloaded pem-file):
volumio@volumio-music:~$ sudo cp unicross-ub-uni-freiburg-de.crt /usr/local/share/ca-certificates
[sudo] password for volumio:
volumio@volumio-music:~$ sudo update-ca-certificates
Updating certificates in /etc/ssl/certs... 1 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d....done.
This was successfull.
Before that I tried:
curl --insecure https://unifm-streams.uni-freiburg.de/unifm.mp3
However, it didn’t work. It gave me a an infinite amount unreadable ASCII-symbols as output.
Excellent. I like volumio. This would never be possible with commercial internet radio receivers!
I had a similar issue, where one certificate in the certificate chain of a site was expired. I followed this Thread. The TLDR Solution:
- Edit
/etc/ca-certificates.conf and put a bang/exclamation mark (!) before mozilla/AddTrust_External_Root.crt
- Run
Was the radio playing fine before the 30th May? Then it is probably due to the expired AddTrust certificate. See my Solution for more details.
