WebRadio with Volumiu
Hello
I use the Volumio with a RaspberryPI Zero with external USB-Wifi Adapter and Soundcard for Internet-Radio, it works verry good.
But sometimes, the stream stocks and i have to press the button play again.
Could someone write a plugin who check the stream and if no stream are playing, that it automatic plays the last stream
Hi zhcip, welcome to Volumio. :slight_smile:
Not sure that would work very well … it would be a 24/7 player, which I don’t think that is what you want to achieve. Is there anything in the system logs at the time that the stream stops?
Have a look at recording system logs
Other than that perhaps it is simply an intenet problem, with the stream site having an interruption in its transmission … irritating, but no idea for a solution. Is it one particular site, or do you find it a problem on a variety of sites?
