Hi all,
I have three Volumio-based systems in my home environment:
- Volumio VM (
volumio01) running v4.119 - Volumio VM (
volumio02) running v4.119 - Pro-Ject Stream Box S2 Ultra (Volumio OEM version)
The problem is that volumio02 fails to play several web radio stations, returning HTTP 404 errors. The same stations work without any issues on volumio01 and on the Stream Box S2 Ultra.
Since the issue is limited to a single instance, I suspect that volumio02 may be using outdated station URLs or an outdated radio station database.
Is there a way to force Volumio to refresh, rescan, or update its web radio station list?
Thanks for your help!
Arno
