Webradio problems
Hello!
Its been a long way installing Volumio 1.55 on RP2 with Adafruit touch screen.
I managed to install WebUi (using Midori browser) on a LXDE-desktop.
My intention is only use web radio and and it’s working quite well, but I have couple problems:
  1. When I add web radio station to my playlist and press play-button the title (radio station name) shows about 2 seconds and then dissapears.
    Instead I can see only ‘path: 192.59.120.30:6066’. This is one of the stations I myself put into WEBRADIO-folder.
    I tried to edit .pls file to match correct format, but no help! The problem occurs in my windows browser and Androin app too.
  2. If I reboot RP2 while web radio is playing, then in the end of boot sequence when LXDE starts music starts to play. Thats ok, but after when midori browser starts it cannot connect to internet. This happens only when web radio plays before reboot. If it is stopped everything is ok.
Is the new Volumio 2 compatible with my PI2 and Adafruit pitft display at the moment?
Thank you for you good work! :smiley:
