New installation on a RPI3. Tried to add my favorite webradio. Got above error.
URL is: abc.net.au/res/streaming/aud … sic_fm.pls
Plays OK in VLC
None of these listed links would play:
radio.abc.net.au/help/streams
Any ideas?
Plays OK in VLC
Any ideas?
Hmm, now I’m further confused.
I have to changed the abc.net.au host name to it’s IP address and it worked. ONCE…
Ok, DNS server issue, I thought. Changed DNS server on the router (rebooted) and tried again. No success. Changed to [Enable Custom Server] in the network tab. No success.
Changed back to IP addressing that worked before. No success ?!?.
Now, the really weird thing is that although neither of my two added stations [IP or hostname] starts to play. But when I go via [QUEUE] and click that one time success it persistently starts the stream.
What am I missing?
Well I can confirm that the stream doesn’t play through Volumio, but does on a PC with VLC. Has it worked with Volumio at all in the past?
Hi
I wonder if the playlist file might be invalid because it includes two version lines
https://en.wikipedia.org/wiki/PLS_(file_format)
[code][playlist]
NumberOfEvents=2
File1=http://live-radio01.mediahubaustralia.com/2FMW/mp3/
Title1=Classic FM NSW
Length1=-1
Version=2
File2=http://live-radio02.mediahubaustralia.com/2FMW/mp3/
Title2=Classic FM NSW
Length2=-1
Version=2[/code]
The links in the file play fine.
Adrian.
Try removing one of the links, and if it works fine then raise a issue on github.com/volumio/Volumio2/issues
Looking again, the problem appears to be that the PLS file says NumberOfEvents, instead of NumberOfEntries. Correcting that, the original file works fine. Here is a test link
Adrian.
Thanks for helping out, guys!
Yes, it seems that the [NumberOfEvents] entry throws off Volumio.
Plugging in one of the URLs included in the PLS file as the webradio URL directly plays the stream just fine. Sorted.
I had the exact same experience - see topic internet-radio-not-working-after-update-t9488.html#p46865.
