I’m using Volumio in a Pi1 B+ with a PCM2704 USB DAC, and I’m experiencing the following problems:
Whenever I start playing anything (I tested MP3 files from a USB HDD, DLNA and webradio streams), i lose control of the web interface until the playback ends. It simply gets stuck into a loading bubble and I can’t use the system whatsoever. It simply dies in there. Wondering if the hardware simply wasn’t fast enough, I’ve attempted overclocking it. It feels snappier overall, but this problem during playback persists and it’s very annoying.
LastFM Scrobbling doesn’t work. I’ve obtained the necessary credentials for my account but no matter what I play, it simply doesn’t scrobble. I’ve enabled SSH and searched through the files for a bit, but I can’t find the debug log that I’ve also enabled to hopefully find out what’s wrong.
I’ve attempted disconnecting the DAC, reverting to audio jack playback, and disabling scrobbling, but the loading bubble keeps blocking the interface during playback.
Could I please get some guidance to solve these issues? I’m liking this system so far and it would be a bummer to switch again.
Thanks in advance.
