Hello again, I connected my Raspberry Pi running Volumio to my home router and restarted it.
The problem is, when I turn it back on, the green activity LED keeps flashing at a fast speed for about 5 minutes before it stops. Yes, it is connected to my router and when I try to access it (the webUI) from it’s IP (10.7.1.10) it just times out.
Note that the Volumio-something wifi network does not appear.
I have a Pi4B with 2GB of RAM. With the monitor plugged in, I just see the login screen. After I log in, it just works as usual. I see the Volumio 3D ascii logo and the usual stuff
please download the latest version from here.
Flash it to the SD card again, seems something went wrong with the previous flash. As there is no need to login at the the terminal.
on first boot, you can enter the credentials of you WiFI network. Complete the installation and reboot. You can access Volumio by it’s given ip or via http://<devicename>.local
But volumio booted up, you did complete the setup?
You can install the Volumio app on your phone and connect to it and check the network settings.
Please post a log:
Please connect a wired network cable to the rPi It seems the WiFI setup failed.
You can also try to connect your phone to the volumio hotspot (Volumioxxxx) and check.
