Hello! Why doesn’t Volumio start the radio from this link?
dnb-liquified.co.uk/stream-info.html
When you create/edit a web radio station in My Web Radios, a pop-up prompts you with;
“The URL can be either a stream URL or a M3U or PLS remote file”
https://whsh4u-clients.com:2199/tunein/ghljsdnh.pls
Not working!
There is a problem with the site’s SSL certificate.
Given that the certificate isn’t valid, you could try and see if using http instead of https works and keep the rest of the URL the same. It’s worth a shot.
