After having upgraded from a beta version 3.051 to a release version of Volumio 3, I no longer see web radio station logos after a station has beed added to favorites and started from there.
This is how a station shows in a station list (country list):
This is how the station looks after having been started from the station list:
One way around it is to add the stations I use most often to Playlists, which seems to retain the logos fine. Here are the steps:
In the Manifest interface (which is free now), click on the icon on the bottom left
On the next screen, click on the save icon on the top row.
You can now save the station as a playlist entry which will retain the logo associated with the station when you go back to it.
I haven’t, however, been able to replicate these steps on the older interfaces to add to the playlist. There is a button to add to playlists in the Contemporary interface but it doesn’t seem to do anything that I can see.
Like I indicated above I have switched to migrating the ones I listen to most often to Playlists which shows the icons when you play the selection (but still doesn’t show in the actual playlist). Don’t know how add icons with web radio listings other than to manually download the icons and then edit the entry in the playlist to point to the icon.
Same question here. Unfortunately it still doesn’t work in the latest version. I listen to the radio a lot and would like to add a display, but without radio logos it is less useful. Will the logos appear in future versions? Btw, I still enjoy using Volumio!
