I would like to clean up all the unwanted webradio entries as well as add Radio paradise. I have read all I can find in the forum but no success.
My Cubox is hard wired to the network and I am trying to follow this:
“1.) when your device is powered on and connected, use your normal computer to open the network folder which is named “volumio”. (In windows: open the explorer and type \volumio\ in the address line)”
What explorer? Internet Explorer? Doesn’t work.
Windows explorer? Cannot access.
I am running windows 7 and I don’t see the “volumio” on my network.
I have used the Webui to add a station with a URL but this does not work even after updating.
Is this a problem with the Cubox installation package?
maybe you have disabled your network detection in windows? If you go to network you should see Volumio (you are in the same network right?), then you can click on it and then open the Webradio folder.
