web interface
In the web interface, large screen, all buttons are displayed with a text like COMMON.TAB_BROWSE, COMMON.TAB_PLAYBACK, …
it should be just BROWSE, PLAYBACK
How can i fix this ?, switching back to english setting in APPEARANCE didn’t solve it
Do you use last version 0.976 ? Is it a fresh install or an update ?
Can you ssh to your device and remove the following file /data/configuration/miscellanea/appearance/config.json
and enter
killall node
perfect !
thank you sir
Thank you - that solved my problem too.
:stuck_out_tongue:
