Hello! I am use last version Volumio 2.246. In the web interface, large screen, all buttons are displayed with a text like COMMON.TAB_BROWSE, COMMON.TAB_PLAYBACK. In this forum I found and done:
What platform are you running? I’m presuming raspberry pi, but which version? I’ve seen this behavior when the Pi is unable to manage everything in time. Refreshing the page mostly solves this, else ctrl+f5 (hard refresh).
I just set up my DigitOne and have the same issue, only been on line for 2 hours and this has popped up. does anyone have a fix?
I re-booted
I shudown removed sim and boot hardware empty, then shutdown and re-booted with sim back in place
I tried background apperance
I tried removing pluggins, but system does not stay on long so cannot
I have Web Radio and Spotify Pluggin
other than re-installes O/S I at a loss.
Dear all,
I’m having the same problem, som buttons showing up with capitalized text (like COMMON.SEARCH etc.) , the usual fixes did not help. My setup is a rpi3 with 2 network interfaces, wlan0 (though which I connect to it) and eth0 which is on a different subnet and connects to my NAS. Now it looks like the web ui is trying to fetch some elements form the ip address belonging to the eth0 interface which is not accessible from wifi. I’m guessing something just takes the first ip address it finds without checking if it makes sense. Browser debug window shows this error message:
192.168.10.100 is the address of the ethernet interface on the other net. Is there a way to specify which interface is to be used for web ui operations?
I have the exact same problem as the original issue posted here in 2017, but with version 2.799.
Changing the interface solves it until the page is reloaded. I have the same issue on my phone app.
Did anyone eventually find a fix?
thanks
edit: I set it in French, looks like the issue is not present in other languages.
