When you tap the 3 dots of an entry (Music library) on top of the screen you won’t get the context menu totally. So i.e. it is impossible to choose “zu Wiedergabeliste hinzufügen” (add to playlist). This doesn’t happen, when you tap on the first or second directory or song (context menu opens downward). It does happen, when you tap on a directory entry located in the middle of the screen or among it. Then the context menu opens upward and the first entrys are hidden - it is not possible to scroll. See screenshot (One Plus 3, Firefox + Standard srowser on LineageOS - landscape + portrait modus).
yes same problmr for me on my 7" waveshare lcd screen. is there any solution?
-> work arround for me is to change the listing style to add the track and then switch back the style
