web client on same raspberry pi as volumio
I installed Volumio on a RPi 3. I am using the HDMI out to my receiver. I thought that might sound better then the 3.5mm jack. My question is it possible to a desktop client on the Volumio system to launch a browser and display the volumio.local web page?
Steve
Where should this WebUI be displayed? If you have a monitor hooked up to your HDMI, you could use the Touch Display plugin.
HDMI. I will give that a try when I get home. Thanks!
Not sure what device you have plugged into the HDMI, but you could also just enable the Kiosk mode, without a touch display.
Not entirely sure if its exclusive to x86 devices, but there might be a toggle in the settings/Setup wizard to enable HDMI output and thus the kiosk mode.
