I try to set up Volumio on my setup with Pi 3B, IQaudio DAC+, 7" touch RPi as a standalone player.
But after installing the Squeezelite plugin and rotating the display 180 degrees and rebooting, the player is no longer available via the web interface. I have tried both via wifi and LAN. I can connect via ssh, is there something I can do to restore the web interface?
Now I can access Volumio via the web interface, and with the 7" touch screen and Squeezeplayer plugin installed. But I don’t find the Logitech Media Server (standalone) from Volumio, and the LMS don’t see the Volumio player.
Then I installed the 7" touch display plugin. Reboot worked ok. Could still access web admin panel. Second the Squeezelite plugin. Third: Installed Audiophonics power button plugin.
Then tried to get a connection with my Logitech Media Server, on another RPi, but did not succeed. Tried to install LMS plugin on Volumio. Did not help. Did a reboot, and after that: no web access.
What I want to have a pi with Squeezelite as a standalone music player that works with my 7" touch screen, be it Jivelite or something else that works.
It works with PiCoreAudio and Max2Play, but I wanted to give Volumio a try.
I just fired up a Pi 2B (and a Boss DAC) with Volumio 2.806. I installed the following plugins (in order)
Cisco DUO (for SSH security)
Spotify (misclicked)
Touch Display (even though I have no screen attached)
Squeezelite player
Audiophonics on/off
All worked fine, then I rebooted and everything still worked fine. The player is auto-advertised to my LMS instance running on Windows Server. I’m now installing LMS on the Pi itself.
Can you elaborate more on how you tried to connect with LMS on the other Pi? Is everything running on the same network segment without any IPS/firewall snooping packets?
For your info, LMS exposes ports 9000 (TCP), 9090 (TCP) and 3483 (TCP & UDP), this should not interfere with the WUI (TCP port 80).
Hi.
As Squeezelite was installed and running I expected the player to appear on my LMS web page, but it did not. I tried to connect from the Volumio web management tool, but didn’t make it. Now I’ll have to reburn the image on the micro SD, not sure when or if I will do.
Of course I have both server and player on the same network.
Maybe you needed to restart Squeezelite once for advertising to work properly. Not sure, didn’t pay too much attention after first install. I could select it from the drop-down (right under my Duet).
i have a similar setup.
I installed volumio and squeezelite plugin on a raspberry pi 3b, and installed picoreplayer/LMS on another raspberry pi 4b with a 3.5 inch touchscreen and it works as a sever.
