Hi everyone, new user to Volumio here!
I’ve come across the Volumio system as a viable solution to distribute music easily with both DACs and have been looking at using this Waveshare WM8960 driver board with small speakers as a little test bench but it does not want to work.
looking at the kernel files for Volumio there is a file for the WM8960 codec installed but if I go through the steps to install the sound card driver I get errors
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area....(bad exit status: 2)
make KERNELRELEASE=3.6-trunk-rpi -C /lib/modules/3.6-trunk-rpi/build M=/var/lib/dkms/wm8960-soundcard/1.0/build....(bad exit status: 2)
Error! Bad return status for module build on kernel: 3.6-trunk-rpi (armv7l)
Consult /var/lib/dkms/wm8960-soundcard/1.0/build/make.log for more information.
Error! echo
Your kernel headers for kernel 4.14.92+ cannot be found at
/lib/modules/4.14.92+/build or /lib/modules/4.14.92+/source.
Error! echo
Your kernel headers for kernel 4.14.92-v7+ cannot be found at
/lib/modules/4.14.92-v7+/build or /lib/modules/4.14.92-v7+/source.
Created symlink from /etc/systemd/system/sysinit.target.wants/wm8960-soundcard.service to /lib/systemd/system/wm8960-soundcard.service.
Please reboot your raspberry pi to apply all settings
Enjoy!
volumio@volumio:~/WM8960-Audio-HAT$ sudo reboot
Anyone able to give me any pointers as to how to have this soundcard installed and functional, the small speaker form factor and smallness of the unit with a pi zero w is what I’m looking for as a test bench.
Thanks All.
