it’s already written in code (bash), the source is me.
got it today, I confirm there is a problem with the drivers made by Raspberry Pi for this model.
Let’s see if I can help to have it fixed by them, providing some parameters for the timing
Thanks a lot @Darmur! I’ve checked the github issues and it seemes they already fixed this driver issue but it requires a kernel update:
good, I’ll take care of patching the driver on kernel 6.1.69
@danidemo please try to enable test mode and update to 3.622
with the patched driver, the 11.9" display works fine.
Also the rotation parameter works fine
dtoverlay=vc4-kms-v3d
dtoverlay=vc4-kms-dsi-waveshare-panel,11_9_inch,rotation=270
I tried on RPi2 and I can use the touch-display plugin
However, when connected to a Pi5, I can see the boot text if the touch-display plugin is disabled. As soon as I enable it, the screen goes blank and the UI is not loaded. The plugin is the version 3.3.8, that already adds the file /etc/X11/xorg.conf.d/99-vc4.conf
@gvolt any clue?
Is it the same without the rotation parameter, i.e.when using just dtoverlay=vc4-kms-dsi-waveshare-panel,11_9_inch?
Please post the content of “/boot/config.txt”, “/boot/volumioconfig.txt” and “/boot/userconfig.txt” and also the output of
cat /var/log/Xorg.0.log
yes, it’s the same with no rotation
[ 68.691]
X.Org X Server 1.20.4
[ 68.691] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 68.691] Current Operating System: Linux volumio-usb 6.1.69-v8+ #1710 SMP PREEMPT Thu Dec 21 13:21:40 GMT 2023 aarch64
[ 68.691] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:7B:C6:00 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA0,115200 console=tty1 imgpart=UUID=09e9eb41-a375-4504-bd95-b9fb31bf869c imgfile=/volumio_current.sqsh bootpart=UUID=1580-EA53 datapart=UUID=5f69cd19-e2eb-4159-a4fb-faef243916c3 bootconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe bootdelay=5 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 68.691] Build Date: 04 April 2023 07:50:56AM
[ 68.691] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 68.691] Current version of pixman: 0.36.0
[ 68.691] Before reporting problems, check http://wiki.x.org
[ 68.691] Markers: (--) probed, (**) from config file, (==) default setting,
[ 68.691] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 15 12:18:09 2024
[ 68.744] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 68.744] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 68.792] (==) No Layout section. Using the first Screen section.
[ 68.792] (==) No screen section available. Using defaults.
[ 68.792] (**) |-->Screen "Default Screen Section" (0)
[ 68.792] (**) | |-->Monitor "<default monitor>"
[ 68.803] (==) No monitor specified for screen "Default Screen Section".
[ 68.803] (==) Automatically adding devices
[ 68.803] (==) Automatically enabling devices
[ 68.803] (==) Automatically adding GPU devices
[ 68.813] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 68.830] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 68.830] Entry deleted from font path.
[ 68.856] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 68.856] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 68.856] (II) The server relies on udev to provide the list of input devices.
[ 68.856] (II) Loader magic: 0x1fdf80
[ 68.856] (II) Module ABI versions:
[ 68.856] X.Org ANSI C Emulation: 0.4
[ 68.856] X.Org Video Driver: 24.0
[ 68.856] X.Org XInput driver : 24.1
[ 68.856] X.Org Server Extension : 10.0
[ 68.857] (--) using VT number 2
[ 68.857] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 68.858] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 68.858] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 68.858] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 68.859] (**) OutputClass "vc4" setting /dev/dri/card2 as PrimaryGPU
[ 68.859] (II) LoadModule: "glx"
[ 68.861] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 68.912] (II) Module glx: vendor="X.Org Foundation"
[ 68.912] compiled for 1.20.4, module version = 1.0.0
[ 68.912] ABI class: X.Org Server Extension, version 10.0
[ 68.912] (II) Applying OutputClass "vc4" to /dev/dri/card2
[ 68.912] loading driver: modesetting
[ 68.912] (==) Matched modesetting as autoconfigured driver 0
[ 68.912] (==) Matched fbdev as autoconfigured driver 1
[ 68.912] (==) Assigned the driver to the xf86ConfigLayout
[ 68.912] (II) LoadModule: "modesetting"
[ 68.921] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 68.929] (II) Module modesetting: vendor="X.Org Foundation"
[ 68.929] compiled for 1.20.4, module version = 1.20.4
[ 68.929] Module class: X.Org Video Driver
[ 68.929] ABI class: X.Org Video Driver, version 24.0
[ 68.929] (II) LoadModule: "fbdev"
[ 68.929] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 68.935] (II) Module fbdev: vendor="X.Org Foundation"
[ 68.935] compiled for 1.20.3, module version = 0.5.0
[ 68.935] Module class: X.Org Video Driver
[ 68.935] ABI class: X.Org Video Driver, version 24.0
[ 68.935] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 68.935] (II) FBDEV: driver for framebuffer: fbdev
[ 68.938] (II) modeset(0): using drv /dev/dri/card2
[ 68.938] (WW) Falling back to old probe method for fbdev
[ 68.938] (II) Loading sub module "fbdevhw"
[ 68.938] (II) LoadModule: "fbdevhw"
[ 68.938] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 68.948] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 68.948] compiled for 1.20.4, module version = 0.0.2
[ 68.948] ABI class: X.Org Video Driver, version 24.0
[ 68.953] (II) modeset(G0): using drv /dev/dri/card1
[ 68.953] (II) modeset(0): Creating default Display subsection in Screen section
[ 68.953] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 68.953] (II) Applying OutputClass "vc4" options to /dev/dri/card2
[ 68.953] (==) modeset(0): RGB weight 888
[ 68.953] (==) modeset(0): Default visual is TrueColor
[ 68.953] (II) Loading sub module "glamoregl"
[ 68.953] (II) LoadModule: "glamoregl"
[ 68.953] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 69.031] (II) Module glamoregl: vendor="X.Org Foundation"
[ 69.031] compiled for 1.20.4, module version = 1.0.1
[ 69.031] ABI class: X.Org ANSI C Emulation, version 0.4
[ 70.608] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 70.609] (EE) modeset(0): glamor initialization failed
[ 70.609] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 70.611] (II) modeset(0): Output HDMI-1 has no monitor section
[ 70.613] (II) modeset(0): Output HDMI-2 has no monitor section
[ 70.614] (II) modeset(0): EDID for output HDMI-1
[ 70.616] (II) modeset(0): EDID for output HDMI-2
[ 70.616] (II) modeset(0): Output HDMI-1 disconnected
[ 70.616] (II) modeset(0): Output HDMI-2 disconnected
[ 70.616] (WW) modeset(0): No outputs definitely connected, trying again...
[ 70.616] (WW) modeset(0): Unable to find connected outputs - setting 1024x768 initial framebuffer
[ 70.616] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 70.616] (==) modeset(0): DPI set to (96, 96)
[ 70.616] (II) Loading sub module "fb"
[ 70.616] (II) LoadModule: "fb"
[ 70.616] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 72.732] (II) Module fb: vendor="X.Org Foundation"
[ 72.732] compiled for 1.20.4, module version = 1.0.0
[ 72.732] ABI class: X.Org ANSI C Emulation, version 0.4
[ 72.732] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 72.732] (==) modeset(G0): RGB weight 888
[ 72.732] (==) modeset(G0): Default visual is TrueColor
[ 72.732] (II) Loading sub module "glamoregl"
[ 72.732] (II) LoadModule: "glamoregl"
[ 72.732] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 72.732] (II) Module glamoregl: vendor="X.Org Foundation"
[ 72.732] compiled for 1.20.4, module version = 1.0.1
[ 72.745] (II) modeset(G0): Refusing to try glamor on llvmpipe
[ 72.745] (EE) modeset(G0): glamor initialization failed
[ 72.745] (II) modeset(G0): ShadowFB: preferred NO, enabled NO
[ 72.746] (II) modeset(G0): Output DSI-1-2 has no monitor section
[ 72.746] (II) modeset(G0): EDID for output DSI-1-2
[ 72.746] (II) modeset(G0): Printing probed modes for output DSI-1-2
[ 72.746] (II) modeset(G0): Modeline "320x1480"x60.2 50.00 320 380 440 500 1480 1540 1600 1660 (100.0 kHz eP)
[ 72.746] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 72.746] (==) modeset(G0): DPI set to (96, 96)
[ 72.746] (II) Loading sub module "fb"
[ 72.746] (II) LoadModule: "fb"
[ 72.746] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 72.746] (II) Module fb: vendor="X.Org Foundation"
[ 72.746] compiled for 1.20.4, module version = 1.0.0
[ 72.746] ABI class: X.Org ANSI C Emulation, version 0.4
[ 72.746] (II) UnloadModule: "fbdev"
[ 72.746] (II) Unloading fbdev
[ 72.746] (II) UnloadSubModule: "fbdevhw"
[ 72.746] (II) Unloading fbdevhw
[ 80.187] (==) modeset(G0): Backing store enabled
[ 80.187] (==) modeset(G0): Silken mouse enabled
[ 80.210] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 80.210] (==) modeset(G0): DPMS enabled
[ 80.211] (==) modeset(0): Backing store enabled
[ 80.211] (==) modeset(0): Silken mouse enabled
[ 80.211] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 80.211] (==) modeset(0): DPMS enabled
[ 80.211] (WW) modeset(0): Option "PrimaryGPU" is not used
[ 80.211] (II) Initializing extension Generic Event Extension
[ 80.212] (II) Initializing extension SHAPE
[ 80.212] (II) Initializing extension MIT-SHM
[ 80.212] (II) Initializing extension XInputExtension
[ 80.220] (II) Initializing extension XTEST
[ 80.221] (II) Initializing extension BIG-REQUESTS
[ 80.221] (II) Initializing extension SYNC
[ 80.221] (II) Initializing extension XKEYBOARD
[ 80.222] (II) Initializing extension XC-MISC
[ 80.222] (II) Initializing extension SECURITY
[ 80.222] (II) Initializing extension XFIXES
[ 80.223] (II) Initializing extension RENDER
[ 80.223] (II) Initializing extension RANDR
[ 80.224] (II) Initializing extension COMPOSITE
[ 80.224] (II) Initializing extension DAMAGE
[ 80.224] (II) Initializing extension MIT-SCREEN-SAVER
[ 80.225] (II) Initializing extension DOUBLE-BUFFER
[ 80.225] (II) Initializing extension RECORD
[ 80.225] (II) Initializing extension DPMS
[ 80.226] (II) Initializing extension Present
[ 80.226] (II) Initializing extension DRI3
[ 80.226] (II) Initializing extension X-Resource
[ 80.226] (II) Initializing extension XVideo
[ 80.226] (II) Initializing extension XVideo-MotionCompensation
[ 80.226] (II) Initializing extension SELinux
[ 80.226] (II) SELinux: Disabled on system
[ 80.226] (II) Initializing extension GLX
[ 80.227] (II) AIGLX: Screen 0 is not DRI2 capable
[ 80.304] (II) IGLX: Loaded and initialized swrast
[ 80.304] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 80.304] (II) Initializing extension XFree86-VidModeExtension
[ 80.305] (II) Initializing extension XFree86-DGA
[ 80.305] (II) Initializing extension XFree86-DRI
[ 80.310] (II) Initializing extension DRI2
[ 83.413] (II) modeset(G0): Damage tracking initialized
[ 83.414] (II) modeset(0): Damage tracking initialized
[ 85.692] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 85.693] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 85.693] (II) LoadModule: "libinput"
[ 85.693] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 85.718] (II) Module libinput: vendor="X.Org Foundation"
[ 85.718] compiled for 1.20.3, module version = 0.28.2
[ 85.718] Module class: X.Org XInput Driver
[ 85.718] ABI class: X.Org XInput driver, version 24.1
[ 85.718] (II) Using input driver 'libinput' for 'pwr_button'
[ 85.718] (**) pwr_button: always reports core events
[ 85.718] (**) Option "Device" "/dev/input/event0"
[ 85.718] (**) Option "_source" "server/udev"
[ 85.744] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 85.744] (II) event0 - pwr_button: device is a keyboard
[ 85.744] (II) event0 - pwr_button: device removed
[ 85.764] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 85.764] (II) XINPUT: Adding extended input device "pwr_button" (type: KEYBOARD, id 6)
[ 85.764] (**) Option "xkb_model" "pc105"
[ 85.764] (**) Option "xkb_layout" "us"
[ 85.765] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 85.765] (II) event0 - pwr_button: device is a keyboard
[ 85.766] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event1)
[ 85.766] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 85.766] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 85.766] (**) vc4-hdmi-0: always reports core events
[ 85.766] (**) Option "Device" "/dev/input/event1"
[ 85.766] (**) Option "_source" "server/udev"
[ 85.767] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 85.767] (II) event1 - vc4-hdmi-0: device is a pointer
[ 85.767] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 85.767] (II) event1 - vc4-hdmi-0: device removed
[ 85.796] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 85.796] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 85.796] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: MOUSE, id 7)
[ 85.796] (**) Option "AccelerationScheme" "none"
[ 85.796] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 85.796] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 85.796] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 85.797] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 85.798] (II) event1 - vc4-hdmi-0: device is a pointer
[ 85.798] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 85.798] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event2)
[ 85.798] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 85.798] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 85.798] (**) vc4-hdmi-1: always reports core events
[ 85.798] (**) Option "Device" "/dev/input/event2"
[ 85.799] (**) Option "_source" "server/udev"
[ 85.800] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 85.800] (II) event2 - vc4-hdmi-1: device is a pointer
[ 85.800] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 85.801] (II) event2 - vc4-hdmi-1: device removed
[ 85.816] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 85.816] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 85.816] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: MOUSE, id 8)
[ 85.816] (**) Option "AccelerationScheme" "none"
[ 85.816] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 85.816] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 85.816] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 85.817] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 85.818] (II) event2 - vc4-hdmi-1: device is a pointer
[ 85.818] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 85.823] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 85.823] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 85.823] (**) vc4-hdmi-0: always reports core events
[ 85.823] (**) Option "Device" "/dev/input/event1"
[ 85.823] (**) Option "_source" "_driver/libinput"
[ 85.823] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 85.824] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 85.824] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: KEYBOARD, id 9)
[ 85.824] (**) Option "xkb_model" "pc105"
[ 85.824] (**) Option "xkb_layout" "us"
[ 85.824] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 85.824] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 85.824] (**) vc4-hdmi-1: always reports core events
[ 85.824] (**) Option "Device" "/dev/input/event2"
[ 85.824] (**) Option "_source" "_driver/libinput"
[ 85.824] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 85.824] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 85.824] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: KEYBOARD, id 10)
[ 85.826] (II) event0 - pwr_button: device removed
[ 85.844] (II) event1 - vc4-hdmi-0: device removed
[ 85.860] (II) event2 - vc4-hdmi-1: device removed
[ 85.876] (II) UnloadModule: "libinput"
[ 85.877] (II) UnloadModule: "libinput"
[ 85.881] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 85.881] (==) modeset(G0): DPMS enabled
[ 85.882] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 85.883] (==) modeset(0): DPMS enabled
[ 85.883] (II) Initializing extension Generic Event Extension
[ 85.883] (II) Initializing extension SHAPE
[ 85.883] (II) Initializing extension MIT-SHM
[ 85.883] (II) Initializing extension XInputExtension
[ 85.884] (II) Initializing extension XTEST
[ 85.884] (II) Initializing extension BIG-REQUESTS
[ 85.884] (II) Initializing extension SYNC
[ 85.885] (II) Initializing extension XKEYBOARD
[ 85.885] (II) Initializing extension XC-MISC
[ 85.885] (II) Initializing extension SECURITY
[ 85.886] (II) Initializing extension XFIXES
[ 85.886] (II) Initializing extension RENDER
[ 85.886] (II) Initializing extension RANDR
[ 85.887] (II) Initializing extension COMPOSITE
[ 85.887] (II) Initializing extension DAMAGE
[ 85.887] (II) Initializing extension MIT-SCREEN-SAVER
[ 85.888] (II) Initializing extension DOUBLE-BUFFER
[ 85.888] (II) Initializing extension RECORD
[ 85.888] (II) Initializing extension DPMS
[ 85.889] (II) Initializing extension Present
[ 85.889] (II) Initializing extension DRI3
[ 85.889] (II) Initializing extension X-Resource
[ 85.889] (II) Initializing extension XVideo
[ 85.889] (II) Initializing extension XVideo-MotionCompensation
[ 85.889] (II) Initializing extension SELinux
[ 85.889] (II) SELinux: Disabled on system
[ 85.889] (II) Initializing extension GLX
[ 85.890] (II) AIGLX: Screen 0 is not DRI2 capable
[ 85.896] (II) IGLX: Loaded and initialized swrast
[ 85.896] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 85.896] (II) Initializing extension XFree86-VidModeExtension
[ 85.897] (II) Initializing extension XFree86-DGA
[ 85.897] (II) Initializing extension XFree86-DRI
[ 85.897] (II) Initializing extension DRI2
[ 85.898] (II) modeset(G0): Damage tracking initialized
[ 85.898] (II) modeset(0): Damage tracking initialized
[ 85.958] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 85.958] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 85.958] (II) Using input driver 'libinput' for 'pwr_button'
[ 85.958] (**) pwr_button: always reports core events
[ 85.958] (**) Option "Device" "/dev/input/event0"
[ 85.958] (**) Option "_source" "server/udev"
[ 85.960] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 85.960] (II) event0 - pwr_button: device is a keyboard
[ 85.960] (II) event0 - pwr_button: device removed
[ 85.980] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 85.980] (**) Option "xkb_model" "pc105"
[ 85.980] (**) Option "xkb_layout" "us"
[ 85.981] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 85.981] (II) event0 - pwr_button: device is a keyboard
[ 85.982] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event1)
[ 85.982] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 85.982] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 85.982] (**) vc4-hdmi-0: always reports core events
[ 85.982] (**) Option "Device" "/dev/input/event1"
[ 85.982] (**) Option "_source" "server/udev"
[ 85.983] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 85.983] (II) event1 - vc4-hdmi-0: device is a pointer
[ 85.983] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 85.984] (II) event1 - vc4-hdmi-0: device removed
[ 86.016] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 86.016] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 86.016] (**) Option "AccelerationScheme" "none"
[ 86.016] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 86.016] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 86.016] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 86.017] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 86.018] (II) event1 - vc4-hdmi-0: device is a pointer
[ 86.018] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 86.019] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event2)
[ 86.019] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 86.019] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 86.019] (**) vc4-hdmi-1: always reports core events
[ 86.019] (**) Option "Device" "/dev/input/event2"
[ 86.019] (**) Option "_source" "server/udev"
[ 86.021] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 86.021] (II) event2 - vc4-hdmi-1: device is a pointer
[ 86.021] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 86.022] (II) event2 - vc4-hdmi-1: device removed
[ 86.040] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 86.040] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 86.040] (**) Option "AccelerationScheme" "none"
[ 86.040] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 86.040] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 86.040] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 86.042] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 86.042] (II) event2 - vc4-hdmi-1: device is a pointer
[ 86.042] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 86.049] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 86.049] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 86.049] (**) vc4-hdmi-0: always reports core events
[ 86.049] (**) Option "Device" "/dev/input/event1"
[ 86.049] (**) Option "_source" "_driver/libinput"
[ 86.049] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 86.049] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 86.049] (**) Option "xkb_model" "pc105"
[ 86.049] (**) Option "xkb_layout" "us"
[ 86.049] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 86.049] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 86.049] (**) vc4-hdmi-1: always reports core events
[ 86.049] (**) Option "Device" "/dev/input/event2"
[ 86.049] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 86.049] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 86.051] (II) event0 - pwr_button: device removed
[ 86.076] (II) event1 - vc4-hdmi-0: device removed
[ 86.104] (II) event2 - vc4-hdmi-1: device removed
[ 86.124] (II) UnloadModule: "libinput"
[ 86.125] (II) UnloadModule: "libinput"
[ 86.129] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 86.129] (==) modeset(G0): DPMS enabled
[ 86.131] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 86.131] (==) modeset(0): DPMS enabled
[ 86.131] (II) Initializing extension Generic Event Extension
[ 86.131] (II) Initializing extension SHAPE
[ 86.131] (II) Initializing extension MIT-SHM
[ 86.132] (II) Initializing extension XInputExtension
[ 86.132] (II) Initializing extension XTEST
[ 86.133] (II) Initializing extension BIG-REQUESTS
[ 86.133] (II) Initializing extension SYNC
[ 86.133] (II) Initializing extension XKEYBOARD
[ 86.134] (II) Initializing extension XC-MISC
[ 86.134] (II) Initializing extension SECURITY
[ 86.134] (II) Initializing extension XFIXES
[ 86.135] (II) Initializing extension RENDER
[ 86.135] (II) Initializing extension RANDR
[ 86.136] (II) Initializing extension COMPOSITE
[ 86.136] (II) Initializing extension DAMAGE
[ 86.136] (II) Initializing extension MIT-SCREEN-SAVER
[ 86.137] (II) Initializing extension DOUBLE-BUFFER
[ 86.137] (II) Initializing extension RECORD
[ 86.137] (II) Initializing extension DPMS
[ 86.138] (II) Initializing extension Present
[ 86.138] (II) Initializing extension DRI3
[ 86.138] (II) Initializing extension X-Resource
[ 86.138] (II) Initializing extension XVideo
[ 86.139] (II) Initializing extension XVideo-MotionCompensation
[ 86.139] (II) Initializing extension SELinux
[ 86.139] (II) SELinux: Disabled on system
[ 86.139] (II) Initializing extension GLX
[ 86.139] (II) AIGLX: Screen 0 is not DRI2 capable
[ 86.145] (II) IGLX: Loaded and initialized swrast
[ 86.145] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 86.145] (II) Initializing extension XFree86-VidModeExtension
[ 86.145] (II) Initializing extension XFree86-DGA
[ 86.145] (II) Initializing extension XFree86-DRI
[ 86.145] (II) Initializing extension DRI2
[ 86.146] (II) modeset(G0): Damage tracking initialized
[ 86.146] (II) modeset(0): Damage tracking initialized
[ 86.204] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 86.204] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 86.204] (II) Using input driver 'libinput' for 'pwr_button'
[ 86.204] (**) pwr_button: always reports core events
[ 86.204] (**) Option "Device" "/dev/input/event0"
[ 86.204] (**) Option "_source" "server/udev"
[ 86.206] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 86.206] (II) event0 - pwr_button: device is a keyboard
[ 86.206] (II) event0 - pwr_button: device removed
[ 86.232] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 86.232] (**) Option "xkb_model" "pc105"
[ 86.232] (**) Option "xkb_layout" "us"
[ 86.233] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 86.233] (II) event0 - pwr_button: device is a keyboard
[ 86.233] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event1)
[ 86.233] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 86.233] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 86.233] (**) vc4-hdmi-0: always reports core events
[ 86.233] (**) Option "Device" "/dev/input/event1"
[ 86.233] (**) Option "_source" "server/udev"
[ 86.235] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 86.235] (II) event1 - vc4-hdmi-0: device is a pointer
[ 86.235] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 86.235] (II) event1 - vc4-hdmi-0: device removed
[ 86.272] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 86.272] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 86.272] (**) Option "AccelerationScheme" "none"
[ 86.272] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 86.272] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 86.272] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 86.273] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 86.274] (II) event1 - vc4-hdmi-0: device is a pointer
[ 86.274] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 86.275] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event2)
[ 86.275] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 86.275] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 86.275] (**) vc4-hdmi-1: always reports core events
[ 86.275] (**) Option "Device" "/dev/input/event2"
[ 86.275] (**) Option "_source" "server/udev"
[ 86.276] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 86.276] (II) event2 - vc4-hdmi-1: device is a pointer
[ 86.276] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 86.277] (II) event2 - vc4-hdmi-1: device removed
[ 86.296] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 86.296] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 86.296] (**) Option "AccelerationScheme" "none"
[ 86.296] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 86.296] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 86.296] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 86.297] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 86.298] (II) event2 - vc4-hdmi-1: device is a pointer
[ 86.298] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 86.304] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 86.304] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 86.304] (**) vc4-hdmi-0: always reports core events
[ 86.304] (**) Option "Device" "/dev/input/event1"
[ 86.304] (**) Option "_source" "_driver/libinput"
[ 86.304] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 86.304] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 86.304] (**) Option "xkb_model" "pc105"
[ 86.304] (**) Option "xkb_layout" "us"
[ 86.304] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 86.304] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 86.304] (**) vc4-hdmi-1: always reports core events
[ 86.304] (**) Option "Device" "/dev/input/event2"
[ 86.304] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 86.304] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
I confirm that with patched driver it works.
But I have removed the configuration in file /etc/X11/xorg.conf.d/99-vc4.conf to view the plugin touch display output, otherwise I got black screen. (my config is rpi5+ dsi waveshare display 11.9)
I’m still fighting with touchscreen rotation and configuration.
After @danidemo’s finding could you post another xorg log after removing “/etc/X11/xorg.conf.d/99-vc4.conf” and restarting the Touch Display plugin, please?
if I remove the file “/etc/X11/xorg.conf.d/99-vc4.conf” the display works also when I enable the touch-display plugin
here the log
[ 44.133]
[ 44.133] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 44.133] Current Operating System: Linux volumio-usb 6.1.69-v8+ #1710 SMP PREEMPT Thu Dec 21 13:21:40 GMT 2023 aarch64
[ 44.133] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=D8:3A:DD:7B:C6:00 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyAMA0,115200 console=tty1 imgpart=UUID=09e9eb41-a375-4504-bd95-b9fb31bf869c imgfile=/volumio_current.sqsh bootpart=UUID=1580-EA53 datapart=UUID=5f69cd19-e2eb-4159-a4fb-faef243916c3 bootconfig=cmdline.txt pcie_aspm=off pci=pcie_bus_safe bootdelay=5 logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 44.133] Build Date: 04 April 2023 07:50:56AM
[ 44.133] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 44.133] Current version of pixman: 0.36.0
[ 44.133] Before reporting problems, check http://wiki.x.org
[ 44.133] Markers: (--) probed, (**) from config file, (==) default setting,
[ 44.133] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Feb 15 14:43:59 2024
[ 44.162] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 44.162] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 44.215] (==) No Layout section. Using the first Screen section.
[ 44.215] (==) No screen section available. Using defaults.
[ 44.215] (**) |-->Screen "Default Screen Section" (0)
[ 44.215] (**) | |-->Monitor "<default monitor>"
[ 44.221] (==) No monitor specified for screen "Default Screen Section".
[ 44.221] (==) Automatically adding devices
[ 44.221] (==) Automatically enabling devices
[ 44.221] (==) Automatically adding GPU devices
[ 44.221] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 44.236] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 44.236] Entry deleted from font path.
[ 44.262] (==) FontPath set to:
built-ins
[ 44.262] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 44.262] (II) The server relies on udev to provide the list of input devices.
[ 44.262] (II) Loader magic: 0x1fdf80
[ 44.262] (II) Module ABI versions:
[ 44.262] X.Org ANSI C Emulation: 0.4
[ 44.262] X.Org Video Driver: 24.0
[ 44.262] X.Org XInput driver : 24.1
[ 44.262] X.Org Server Extension : 10.0
[ 44.262] (--) using VT number 2
[ 44.262] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 44.264] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 44.267] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 44.267] (II) xfree86: Adding drm device (/dev/dri/card2)
[ 44.268] (II) no primary bus or device found
[ 44.268] falling back to /sys/devices/platform/axi/1000120000.pcie/1f00130000.dsi/drm/card1
[ 44.268] (II) LoadModule: "glx"
[ 44.286] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 44.429] (II) Module glx: vendor="X.Org Foundation"
[ 44.429] compiled for 1.20.4, module version = 1.0.0
[ 44.429] ABI class: X.Org Server Extension, version 10.0
[ 44.429] (==) Matched modesetting as autoconfigured driver 0
[ 44.429] (==) Matched fbdev as autoconfigured driver 1
[ 44.429] (==) Assigned the driver to the xf86ConfigLayout
[ 44.429] (II) LoadModule: "modesetting"
[ 44.445] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 44.468] (II) Module modesetting: vendor="X.Org Foundation"
[ 44.468] compiled for 1.20.4, module version = 1.20.4
[ 44.468] Module class: X.Org Video Driver
[ 44.468] ABI class: X.Org Video Driver, version 24.0
[ 44.468] (II) LoadModule: "fbdev"
[ 44.468] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 44.487] (II) Module fbdev: vendor="X.Org Foundation"
[ 44.487] compiled for 1.20.3, module version = 0.5.0
[ 44.487] Module class: X.Org Video Driver
[ 44.487] ABI class: X.Org Video Driver, version 24.0
[ 44.487] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 44.487] (II) FBDEV: driver for framebuffer: fbdev
[ 44.516] (II) modeset(0): using drv /dev/dri/card1
[ 44.516] (WW) Falling back to old probe method for fbdev
[ 44.516] (II) Loading sub module "fbdevhw"
[ 44.516] (II) LoadModule: "fbdevhw"
[ 44.516] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 44.566] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 44.566] compiled for 1.20.4, module version = 0.0.2
[ 44.566] ABI class: X.Org Video Driver, version 24.0
[ 44.566] (II) modeset(G0): using drv /dev/dri/card2
[ 44.567] (II) modeset(0): Creating default Display subsection in Screen section
[ 44.567] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 44.567] (==) modeset(0): RGB weight 888
[ 44.567] (==) modeset(0): Default visual is TrueColor
[ 44.567] (II) Loading sub module "glamoregl"
[ 44.567] (II) LoadModule: "glamoregl"
[ 44.567] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 44.658] (II) Module glamoregl: vendor="X.Org Foundation"
[ 44.658] compiled for 1.20.4, module version = 1.0.1
[ 44.658] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.893] (II) modeset(0): Refusing to try glamor on llvmpipe
[ 45.894] (EE) modeset(0): glamor initialization failed
[ 45.894] (II) modeset(0): ShadowFB: preferred NO, enabled NO
[ 45.895] (II) modeset(0): Output DSI-2 has no monitor section
[ 45.895] (II) modeset(0): EDID for output DSI-2
[ 45.895] (II) modeset(0): Printing probed modes for output DSI-2
[ 45.895] (II) modeset(0): Modeline "320x1480"x60.2 50.00 320 380 440 500 1480 1540 1600 1660 (100.0 kHz eP)
[ 45.895] (II) modeset(0): Output DSI-2 connected
[ 45.895] (II) modeset(0): Using exact sizes for initial modes
[ 45.895] (II) modeset(0): Output DSI-2 using initial mode 320x1480 +0+0
[ 45.895] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 45.895] (==) modeset(0): DPI set to (96, 96)
[ 45.895] (II) Loading sub module "fb"
[ 45.895] (II) LoadModule: "fb"
[ 45.895] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 45.900] (II) Module fb: vendor="X.Org Foundation"
[ 45.900] compiled for 1.20.4, module version = 1.0.0
[ 45.900] ABI class: X.Org ANSI C Emulation, version 0.4
[ 45.900] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 45.900] (==) modeset(G0): RGB weight 888
[ 45.900] (==) modeset(G0): Default visual is TrueColor
[ 45.900] (II) Loading sub module "glamoregl"
[ 45.900] (II) LoadModule: "glamoregl"
[ 45.900] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 45.900] (II) Module glamoregl: vendor="X.Org Foundation"
[ 45.900] compiled for 1.20.4, module version = 1.0.1
[ 46.285] (II) modeset(G0): Refusing to try glamor on llvmpipe
[ 46.286] (EE) modeset(G0): glamor initialization failed
[ 46.286] (II) modeset(G0): ShadowFB: preferred NO, enabled NO
[ 46.292] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 46.294] (II) modeset(G0): Output HDMI-1-2 has no monitor section
[ 46.296] (II) modeset(G0): EDID for output HDMI-1-1
[ 46.298] (II) modeset(G0): EDID for output HDMI-1-2
[ 46.298] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 46.298] (==) modeset(G0): DPI set to (96, 96)
[ 46.298] (II) Loading sub module "fb"
[ 46.298] (II) LoadModule: "fb"
[ 46.298] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 46.298] (II) Module fb: vendor="X.Org Foundation"
[ 46.298] compiled for 1.20.4, module version = 1.0.0
[ 46.298] ABI class: X.Org ANSI C Emulation, version 0.4
[ 46.298] (II) UnloadModule: "fbdev"
[ 46.298] (II) Unloading fbdev
[ 46.298] (II) UnloadSubModule: "fbdevhw"
[ 46.298] (II) Unloading fbdevhw
[ 46.318] (==) modeset(G0): Backing store enabled
[ 46.318] (==) modeset(G0): Silken mouse enabled
[ 46.327] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 46.327] (==) modeset(G0): DPMS enabled
[ 46.327] (==) modeset(0): Backing store enabled
[ 46.327] (==) modeset(0): Silken mouse enabled
[ 46.342] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 46.342] (==) modeset(0): DPMS enabled
[ 46.342] (II) Initializing extension Generic Event Extension
[ 46.343] (II) Initializing extension SHAPE
[ 46.343] (II) Initializing extension MIT-SHM
[ 46.343] (II) Initializing extension XInputExtension
[ 46.347] (II) Initializing extension XTEST
[ 46.347] (II) Initializing extension BIG-REQUESTS
[ 46.348] (II) Initializing extension SYNC
[ 46.348] (II) Initializing extension XKEYBOARD
[ 46.348] (II) Initializing extension XC-MISC
[ 46.349] (II) Initializing extension SECURITY
[ 46.349] (II) Initializing extension XFIXES
[ 46.349] (II) Initializing extension RENDER
[ 46.350] (II) Initializing extension RANDR
[ 46.350] (II) Initializing extension COMPOSITE
[ 46.351] (II) Initializing extension DAMAGE
[ 46.351] (II) Initializing extension MIT-SCREEN-SAVER
[ 46.351] (II) Initializing extension DOUBLE-BUFFER
[ 46.352] (II) Initializing extension RECORD
[ 46.352] (II) Initializing extension DPMS
[ 46.352] (II) Initializing extension Present
[ 46.353] (II) Initializing extension DRI3
[ 46.353] (II) Initializing extension X-Resource
[ 46.353] (II) Initializing extension XVideo
[ 46.354] (II) Initializing extension XVideo-MotionCompensation
[ 46.354] (II) Initializing extension SELinux
[ 46.354] (II) SELinux: Disabled on system
[ 46.354] (II) Initializing extension GLX
[ 46.354] (II) AIGLX: Screen 0 is not DRI2 capable
[ 46.406] (II) IGLX: Loaded and initialized swrast
[ 46.406] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 46.406] (II) Initializing extension XFree86-VidModeExtension
[ 46.406] (II) Initializing extension XFree86-DGA
[ 46.406] (II) Initializing extension XFree86-DRI
[ 46.409] (II) Initializing extension DRI2
[ 46.409] (II) modeset(G0): Damage tracking initialized
[ 46.410] (II) modeset(0): Damage tracking initialized
[ 46.410] (II) modeset(0): Setting screen physical size to 84 x 391
[ 46.528] (II) config/udev: Adding input device 4-0014 Goodix Capacitive TouchScreen (/dev/input/event3)
[ 46.528] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput keyboard catchall"
[ 46.528] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput touchscreen catchall"
[ 46.528] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "Touch rotation"
[ 46.528] (II) LoadModule: "libinput"
[ 46.528] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 46.549] (II) Module libinput: vendor="X.Org Foundation"
[ 46.549] compiled for 1.20.3, module version = 0.28.2
[ 46.549] Module class: X.Org XInput Driver
[ 46.549] ABI class: X.Org XInput driver, version 24.1
[ 46.549] (II) Using input driver 'libinput' for '4-0014 Goodix Capacitive TouchScreen'
[ 46.549] (**) 4-0014 Goodix Capacitive TouchScreen: always reports core events
[ 46.549] (**) Option "Device" "/dev/input/event3"
[ 46.549] (**) Option "_source" "server/udev"
[ 46.571] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: is tagged by udev as: Keyboard Touchscreen
[ 46.571] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: device is a keyboard
[ 46.571] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: device is a touch device
[ 46.572] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: device removed
[ 46.588] (II) libinput: 4-0014 Goodix Capacitive TouchScreen: needs a virtual subdevice
[ 46.588] (**) Option "config_info" "udev:/sys/devices/platform/axi/1000120000.pcie/1f00080000.i2c/i2c-4/4-0014/input/input3/event3"
[ 46.588] (II) XINPUT: Adding extended input device "4-0014 Goodix Capacitive TouchScreen" (type: TOUCHSCREEN, id 6)
[ 46.588] (**) Option "AccelerationScheme" "none"
[ 46.588] (**) 4-0014 Goodix Capacitive TouchScreen: (accel) selected scheme none/0
[ 46.588] (**) 4-0014 Goodix Capacitive TouchScreen: (accel) acceleration factor: 2.000
[ 46.588] (**) 4-0014 Goodix Capacitive TouchScreen: (accel) acceleration threshold: 4
[ 46.590] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: is tagged by udev as: Keyboard Touchscreen
[ 46.591] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: device is a keyboard
[ 46.591] (II) event3 - 4-0014 Goodix Capacitive TouchScreen: device is a touch device
[ 46.592] (II) config/udev: Adding input device 4-0014 Goodix Capacitive TouchScreen (/dev/input/mouse0)
[ 46.592] (II) No input driver specified, ignoring this device.
[ 46.592] (II) This device may have been added with another device file.
[ 46.594] (II) config/udev: Adding input device pwr_button (/dev/input/event0)
[ 46.594] (**) pwr_button: Applying InputClass "libinput keyboard catchall"
[ 46.594] (II) Using input driver 'libinput' for 'pwr_button'
[ 46.594] (**) pwr_button: always reports core events
[ 46.594] (**) Option "Device" "/dev/input/event0"
[ 46.594] (**) Option "_source" "server/udev"
[ 46.595] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 46.595] (II) event0 - pwr_button: device is a keyboard
[ 46.595] (II) event0 - pwr_button: device removed
[ 46.632] (**) Option "config_info" "udev:/sys/devices/platform/pwr_button/input/input0/event0"
[ 46.632] (II) XINPUT: Adding extended input device "pwr_button" (type: KEYBOARD, id 7)
[ 46.632] (**) Option "xkb_model" "pc105"
[ 46.632] (**) Option "xkb_layout" "us"
[ 46.633] (II) event0 - pwr_button: is tagged by udev as: Keyboard
[ 46.633] (II) event0 - pwr_button: device is a keyboard
[ 46.634] (II) config/udev: Adding input device vc4-hdmi-0 (/dev/input/event1)
[ 46.634] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 46.634] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 46.634] (**) vc4-hdmi-0: always reports core events
[ 46.634] (**) Option "Device" "/dev/input/event1"
[ 46.634] (**) Option "_source" "server/udev"
[ 46.636] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 46.637] (II) event1 - vc4-hdmi-0: device is a pointer
[ 46.637] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 46.637] (II) event1 - vc4-hdmi-0: device removed
[ 46.676] (II) libinput: vc4-hdmi-0: needs a virtual subdevice
[ 46.676] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 46.676] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: MOUSE, id 8)
[ 46.676] (**) Option "AccelerationScheme" "none"
[ 46.676] (**) vc4-hdmi-0: (accel) selected scheme none/0
[ 46.676] (**) vc4-hdmi-0: (accel) acceleration factor: 2.000
[ 46.676] (**) vc4-hdmi-0: (accel) acceleration threshold: 4
[ 46.678] (II) event1 - vc4-hdmi-0: is tagged by udev as: Keyboard Pointingstick
[ 46.678] (II) event1 - vc4-hdmi-0: device is a pointer
[ 46.678] (II) event1 - vc4-hdmi-0: device is a keyboard
[ 46.680] (II) config/udev: Adding input device vc4-hdmi-1 (/dev/input/event2)
[ 46.680] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 46.680] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 46.680] (**) vc4-hdmi-1: always reports core events
[ 46.680] (**) Option "Device" "/dev/input/event2"
[ 46.680] (**) Option "_source" "server/udev"
[ 46.682] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 46.682] (II) event2 - vc4-hdmi-1: device is a pointer
[ 46.682] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 46.683] (II) event2 - vc4-hdmi-1: device removed
[ 46.708] (II) libinput: vc4-hdmi-1: needs a virtual subdevice
[ 46.708] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 46.708] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: MOUSE, id 9)
[ 46.708] (**) Option "AccelerationScheme" "none"
[ 46.708] (**) vc4-hdmi-1: (accel) selected scheme none/0
[ 46.708] (**) vc4-hdmi-1: (accel) acceleration factor: 2.000
[ 46.708] (**) vc4-hdmi-1: (accel) acceleration threshold: 4
[ 46.710] (II) event2 - vc4-hdmi-1: is tagged by udev as: Keyboard Pointingstick
[ 46.710] (II) event2 - vc4-hdmi-1: device is a pointer
[ 46.710] (II) event2 - vc4-hdmi-1: device is a keyboard
[ 46.724] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput keyboard catchall"
[ 46.724] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "libinput touchscreen catchall"
[ 46.724] (**) 4-0014 Goodix Capacitive TouchScreen: Applying InputClass "Touch rotation"
[ 46.724] (II) Using input driver 'libinput' for '4-0014 Goodix Capacitive TouchScreen'
[ 46.724] (**) 4-0014 Goodix Capacitive TouchScreen: always reports core events
[ 46.724] (**) Option "Device" "/dev/input/event3"
[ 46.724] (**) Option "_source" "_driver/libinput"
[ 46.724] (II) libinput: 4-0014 Goodix Capacitive TouchScreen: is a virtual subdevice
[ 46.724] (**) Option "config_info" "udev:/sys/devices/platform/axi/1000120000.pcie/1f00080000.i2c/i2c-4/4-0014/input/input3/event3"
[ 46.724] (II) XINPUT: Adding extended input device "4-0014 Goodix Capacitive TouchScreen" (type: KEYBOARD, id 10)
[ 46.724] (**) Option "xkb_model" "pc105"
[ 46.724] (**) Option "xkb_layout" "us"
[ 46.725] (**) vc4-hdmi-0: Applying InputClass "libinput keyboard catchall"
[ 46.725] (II) Using input driver 'libinput' for 'vc4-hdmi-0'
[ 46.725] (**) vc4-hdmi-0: always reports core events
[ 46.725] (**) Option "Device" "/dev/input/event1"
[ 46.725] (**) Option "_source" "_driver/libinput"
[ 46.725] (II) libinput: vc4-hdmi-0: is a virtual subdevice
[ 46.725] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c701400.hdmi/rc/rc0/input1/event1"
[ 46.725] (II) XINPUT: Adding extended input device "vc4-hdmi-0" (type: KEYBOARD, id 11)
[ 46.725] (**) Option "xkb_model" "pc105"
[ 46.725] (**) Option "xkb_layout" "us"
[ 46.725] (**) vc4-hdmi-1: Applying InputClass "libinput keyboard catchall"
[ 46.725] (II) Using input driver 'libinput' for 'vc4-hdmi-1'
[ 46.725] (**) vc4-hdmi-1: always reports core events
[ 46.725] (**) Option "Device" "/dev/input/event2"
[ 46.725] (II) libinput: vc4-hdmi-1: is a virtual subdevice
[ 46.725] (**) Option "config_info" "udev:/sys/devices/platform/soc/107c706400.hdmi/rc/rc1/input2/event2"
[ 46.725] (II) XINPUT: Adding extended input device "vc4-hdmi-1" (type: KEYBOARD, id 12)
[ 47.783] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 47.920] (II) modeset(0): Allocate new frame buffer 1480x320 stride
[ 88.810] (II) Axis 0x35 value 1684 is outside expected range [-15, 334]
See https://wayland.freedesktop.org/libinput/doc/1.12.6/absolute_coordinate_ranges.html for details
for rotating the display, I’ve added this to /home/volumio/.config/openbox/autostart
xrandr --output DSI-2 --rotate left
here it is
volumio@volumio-usb:~$ ls /dev/dri/by-path
platform-1002000000.v3d-card platform-1002000000.v3d-render platform-1f00130000.dsi-card platform-axi:gpu-card
Please try changing Identifier and MatchDriver in “99-vc4.conf” like this:
Section "OutputClass"
Identifier "rp1"
MatchDriver "rp1-vec|rp1-dsi|rp1-dpi"
Driver "modesetting"
Option "PrimaryGPU" "true"
EndSection
it works!
So I think this combined version of “99-vc4.conf” should work, too:
Identifier "vc4"
MatchDriver "vc4"
EndSection
Identifier "rp1"
EndSection
Could you do another test, please?
sure!
unfortunately it doesn’t work, blank screen again
volumio@volumio-nvme:~$ cat /etc/X11/xorg.conf.d/99-vc4.conf
Identifier "vc4"
MatchDriver "vc4"
EndSection
Identifier "rp1"
EndSection
Too bad…
Could you try if changing the order of the two OutputClass sections helps?
I would also be interested in the output of
cat /proc/modules
even inverting the order, it doesn’t work… blank screen after reboot
Identifier "rp1"
EndSection
Identifier "vc4"
MatchDriver "vc4"
EndSection
removing the section with identifier vc4, the display works again (after reboot of course)
here the output you requested (obtained with two sections on 99-vc4.conf, in the order reported above)
volumio@volumio-nvme:~$ cat /proc/modules
nft_chain_nat 16384 4 - Live 0x0000000000000000
bnep 24576 2 - Live 0x0000000000000000
xt_REDIRECT 16384 1 - Live 0x0000000000000000
nf_nat 49152 2 nft_chain_nat,xt_REDIRECT, Live 0x0000000000000000
nf_conntrack 147456 2 xt_REDIRECT,nf_nat, Live 0x0000000000000000
nf_defrag_ipv6 20480 1 nf_conntrack, Live 0x0000000000000000
nf_defrag_ipv4 16384 1 nf_conntrack, Live 0x0000000000000000
xt_tcpudp 16384 1 - Live 0x0000000000000000
nft_compat 20480 2 - Live 0x0000000000000000
nf_tables 249856 5 nft_chain_nat,nft_compat, Live 0x0000000000000000
nfnetlink 20480 2 nft_compat,nf_tables, Live 0x0000000000000000
8021q 32768 0 - Live 0x0000000000000000
garp 16384 1 8021q, Live 0x0000000000000000
stp 16384 1 garp, Live 0x0000000000000000
llc 16384 2 garp,stp, Live 0x0000000000000000
joydev 28672 0 - Live 0x0000000000000000
brcmfmac 327680 0 - Live 0x0000000000000000
panel_waveshare_dsi 16384 0 - Live 0x0000000000000000
spidev 20480 0 - Live 0x0000000000000000
goodix_ts 28672 0 - Live 0x0000000000000000
brcmutil 24576 1 brcmfmac, Live 0x0000000000000000
cfg80211 929792 1 brcmfmac, Live 0x0000000000000000
hci_uart 53248 0 - Live 0x0000000000000000
btbcm 24576 1 hci_uart, Live 0x0000000000000000
bluetooth 565248 24 bnep,hci_uart,btbcm, Live 0x0000000000000000
aes_ce_blk 32768 1 - Live 0x0000000000000000
aes_ce_cipher 16384 1 aes_ce_blk, Live 0x0000000000000000
ghash_ce 20480 0 - Live 0x0000000000000000
gf128mul 16384 1 ghash_ce, Live 0x0000000000000000
ecdh_generic 16384 2 bluetooth, Live 0x0000000000000000
sha2_ce 16384 0 - Live 0x0000000000000000
ecc 36864 1 ecdh_generic, Live 0x0000000000000000
sha256_arm64 24576 1 sha2_ce, Live 0x0000000000000000
rfkill 32768 6 cfg80211,bluetooth, Live 0x0000000000000000
snd_soc_rpi_simple_soundcard 20480 1 - Live 0x0000000000000000
sha1_ce 16384 0 - Live 0x0000000000000000
libaes 16384 4 bluetooth,aes_ce_blk,aes_ce_cipher,ghash_ce, Live 0x0000000000000000
vc4 372736 7 - Live 0x0000000000000000
raspberrypi_hwmon 16384 0 - Live 0x0000000000000000
v3d 90112 0 - Live 0x0000000000000000
rpivid_hevc 53248 0 - Live 0x0000000000000000 (C)
snd_soc_hdmi_codec 20480 2 - Live 0x0000000000000000
pisp_be 32768 0 - Live 0x0000000000000000
drm_display_helper 16384 1 vc4, Live 0x0000000000000000
v4l2_mem2mem 45056 1 rpivid_hevc, Live 0x0000000000000000
gpu_sched 49152 1 v3d, Live 0x0000000000000000
videobuf2_dma_contig 20480 2 rpivid_hevc,pisp_be, Live 0x0000000000000000
cec 53248 1 vc4, Live 0x0000000000000000
designware_i2s 24576 2 - Live 0x0000000000000000
drm_rp1_dsi 20480 1 - Live 0x0000000000000000
snd_soc_pcm1794a 16384 1 - Live 0x0000000000000000
drm_shmem_helper 24576 1 v3d, Live 0x0000000000000000
drm_dma_helper 20480 2 vc4,drm_rp1_dsi, Live 0x0000000000000000
drm_kms_helper 204800 6 vc4,drm_rp1_dsi,drm_dma_helper, Live 0x0000000000000000
snd_soc_core 274432 5 snd_soc_rpi_simple_soundcard,vc4,snd_soc_hdmi_codec,designware_i2s,snd_soc_pcm1794a, Live 0x0000000000000000
videobuf2_memops 16384 1 videobuf2_dma_contig, Live 0x0000000000000000
videobuf2_v4l2 32768 3 rpivid_hevc,pisp_be,v4l2_mem2mem, Live 0x0000000000000000
videobuf2_common 69632 6 rpivid_hevc,pisp_be,v4l2_mem2mem,videobuf2_dma_contig,videobuf2_memops,videobuf2_v4l2, Live 0x0000000000000000
i2c_brcmstb 16384 0 - Live 0x0000000000000000
spi_bcm2835 20480 0 - Live 0x0000000000000000
snd_compress 20480 1 snd_soc_core, Live 0x0000000000000000
snd_pcm_dmaengine 20480 1 snd_soc_core, Live 0x0000000000000000
videodev 274432 5 rpivid_hevc,pisp_be,v4l2_mem2mem,videobuf2_v4l2,videobuf2_common, Live 0x0000000000000000
snd_seq 73728 0 - Live 0x0000000000000000
drm 581632 12 panel_waveshare_dsi,vc4,v3d,drm_display_helper,gpu_sched,drm_rp1_dsi,drm_shmem_helper,drm_dma_helper,drm_kms_helper, Live 0x0000000000000000
snd_pcm 139264 6 snd_soc_rpi_simple_soundcard,snd_soc_hdmi_codec,designware_i2s,snd_soc_core,snd_compress,snd_pcm_dmaengine, Live 0x0000000000000000
snd_seq_device 16384 1 snd_seq, Live 0x0000000000000000
mc 61440 6 rpivid_hevc,pisp_be,v4l2_mem2mem,videobuf2_v4l2,videobuf2_common,videodev, Live 0x0000000000000000
pwm_fan 20480 0 - Live 0x0000000000000000
snd_timer 36864 2 snd_seq,snd_pcm, Live 0x0000000000000000
drm_panel_orientation_quirks 28672 1 drm, Live 0x0000000000000000
fb_sys_fops 16384 1 drm_kms_helper, Live 0x0000000000000000
syscopyarea 16384 1 drm_kms_helper, Live 0x0000000000000000
sysfillrect 16384 1 drm_kms_helper, Live 0x0000000000000000
gpio_keys 20480 0 - Live 0x0000000000000000
sysimgblt 16384 1 drm_kms_helper, Live 0x0000000000000000
snd 106496 13 snd_soc_hdmi_codec,snd_soc_core,snd_compress,snd_seq,snd_pcm,snd_seq_device,snd_timer, Live 0x0000000000000000
backlight 24576 2 panel_waveshare_dsi,drm, Live 0x0000000000000000
raspberrypi_gpiomem 16384 0 - Live 0x0000000000000000
i2c_designware_platform 16384 0 - Live 0x0000000000000000
i2c_designware_core 24576 1 i2c_designware_platform, Live 0x0000000000000000
rp1_adc 16384 0 - Live 0x0000000000000000
uio_pdrv_genirq 16384 0 - Live 0x0000000000000000
uio 24576 1 uio_pdrv_genirq, Live 0x0000000000000000
nvmem_rmem 16384 0 - Live 0x0000000000000000
i2c_dev 20480 0 - Live 0x0000000000000000
ip_tables 32768 0 - Live 0x0000000000000000
x_tables 53248 4 xt_REDIRECT,xt_tcpudp,nft_compat,ip_tables, Live 0x0000000000000000
ipv6 557056 88 [permanent], Live 0x0000000000000000
fuse 135168 1 - Live 0x0000000000000000
squashfs 49152 1 - Live 0x0000000000000000
overlay 126976 1 - Live 0x0000000000000000
