What lines and where do I need to add for this display to work with Volumio 4?
I get it work easily with the standard Image using the Raspberry imager by adding a couple of lines to Config.tx but no luck in Volumio 4.
Do I add a file called “userconfig.txt” and if so, where does it need to reside and what lines of code does it need. I’ve tried about 20 different combinations and locations and nada.
Thank you. Do I need any other plugins installed before/after this? I’ve tried this and picked every variation of the Waveshare 8" to no avail. I know the display and connection works, as it displays the raspberry Pi OS perfectly on first boot.
Also, no matter which options I select during the "wizard: setup, after reboot (nothing displays as at any point) when i go back to the Plugin the Settings have defaulted back to the original “starting” options.
