I greet you all
This is my first post on this forum.
If at the beginning I didn’t know anything about debian from this forum I learned something.
My problem is that I cannot rotate a display 180 degrees.
I use a raspberry pi 3 B and a display MPI3501 driver ILI9486 with touchscreen and Volumio-3.661-2024-04-24-pi
The touchscreen works rotated 180 degrees, but the display does not.
I attach :
config.txt
userconfig.txt
Xorg.0.log
99-calibration.conf
99-fbturbo.conf
config.txt
### DO NOT EDIT THIS FILE ###
initramfs volumio.initrd
gpu_mem=128
gpu_mem_256=32
gpu_mem_512=32
gpu_mem_1024=128
max_usb_current=1
[pi5]
usb_max_current_enable=1
[all]
include volumioconfig.txt
include userconfig.txt
userconfig.txt
dtparam=spi=on
dtoverlay=waveshare35a
hdmi_force_hotplug=1
max_usb_current=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 480 320 60 6 0 0 0
hdmi_drive=2
display_rotate=0
display_lcd_rotate=2
display_hdmi_rotate=2
Xorg.0.log
[ 50.354]
X.Org X Server 1.20.4
[ 50.354] Build Operating System: Linux 5.4.0-109-generic armv8l Raspbian
[ 50.354] Current Operating System: Linux tity-rpi3 6.1.69-v7+ #1710 SMP Thu Dec 21 13:14:13 GMT 2023 armv7l
[ 50.354] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=480 bcm2708_fb.fbheight=320 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa= snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 loglevel=0
[ 50.354] Build Date: 04 April 2023 07:50:56AM
[ 50.354] xorg-server 2:1.20.4-1+rpt4+deb10u9 (https://www.debian.org/support)
[ 50.354] Current version of pixman: 0.36.0
[ 50.354] Before reporting problems, check http://wiki.x.org
[ 50.354] Markers: (--) probed, (**) from config file, (==) default setting,
[ 50.355] (==) Log file: "/var/log/Xorg.0.log", Time: Wed May 29 11:41:07 2024
[ 50.366] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 50.366] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 50.374] (==) No Layout section. Using the first Screen section.
[ 50.374] (==) No screen section available. Using defaults.
[ 50.374] (**) |-->Screen "Default Screen Section" (0)
[ 50.374] (**) | |-->Monitor "<default monitor>"
[ 50.381] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 50.381] (**) | |-->Device "Allwinner A10/A13 FBDEV"
[ 50.381] (==) No monitor specified for screen "Default Screen Section".
[ 50.381] (==) Automatically adding devices
[ 50.381] (==) Automatically enabling devices
[ 50.381] (==) Automatically adding GPU devices
[ 50.381] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 50.382] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 50.382] Entry deleted from font path.
[ 50.384] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 50.384] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 50.384] (II) The server relies on udev to provide the list of input devices.
[ 50.384] (II) Loader magic: 0x1fdf80
[ 50.384] (II) Module ABI versions:
[ 50.384] X.Org ANSI C Emulation: 0.4
[ 50.384] X.Org Video Driver: 24.0
[ 50.384] X.Org XInput driver : 24.1
[ 50.384] X.Org Server Extension : 10.0
[ 50.387] (--) using VT number 2
[ 50.387] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 50.387] (II) no primary bus or device found
[ 50.387] (II) LoadModule: "glx"
[ 50.391] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 50.441] (II) Module glx: vendor="X.Org Foundation"
[ 50.441] compiled for 1.20.4, module version = 1.0.0
[ 50.441] ABI class: X.Org Server Extension, version 10.0
[ 50.441] (II) LoadModule: "fbturbo"
[ 50.441] (II) Loading /usr/lib/xorg/modules/drivers/fbturbo_drv.so
[ 50.445] (II) Module fbturbo: vendor="X.Org Foundation"
[ 50.445] compiled for 1.20.3, module version = 0.5.1
[ 50.445] Module class: X.Org Video Driver
[ 50.445] ABI class: X.Org Video Driver, version 24.0
[ 50.445] (II) FBTURBO: driver for framebuffer: fbturbo
[ 50.447] (WW) Falling back to old probe method for fbturbo
[ 50.447] (II) Loading sub module "fbdevhw"
[ 50.447] (II) LoadModule: "fbdevhw"
[ 50.447] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 50.450] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 50.450] compiled for 1.20.4, module version = 0.0.2
[ 50.450] ABI class: X.Org Video Driver, version 24.0
[ 50.450] (II) FBTURBO(0): using /dev/fb1
[ 50.450] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 50.450] (II) FBTURBO(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 16/16
[ 50.450] (==) FBTURBO(0): Depth 16, (==) framebuffer bpp 16
[ 50.450] (==) FBTURBO(0): RGB weight 565
[ 50.450] (==) FBTURBO(0): Default visual is TrueColor
[ 50.450] (==) FBTURBO(0): Using gamma correction (1.0, 1.0, 1.0)
[ 50.450] (II) FBTURBO(0): hardware: fb_ili9486 (video memory: 300kB)
[ 50.450] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 50.450] (**) FBTURBO(0): Option "fbdev" "/dev/fb1"
[ 50.450] (**) FBTURBO(0): Option "SwapbuffersWait" "true"
[ 50.451] (II) FBTURBO(0): processor: Unknown
[ 50.451] (II) FBTURBO(0): checking modes against framebuffer device...
[ 50.451] (II) FBTURBO(0): checking modes against monitor...
[ 50.451] (II) FBTURBO(0): Virtual size is 480x320 (pitch 480)
[ 50.451] (**) FBTURBO(0): Built-in mode "current"
[ 50.451] (==) FBTURBO(0): DPI set to (96, 96)
[ 50.451] (II) Loading sub module "fb"
[ 50.451] (II) LoadModule: "fb"
[ 50.451] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 50.456] (II) Module fb: vendor="X.Org Foundation"
[ 50.456] compiled for 1.20.4, module version = 1.0.0
[ 50.456] ABI class: X.Org ANSI C Emulation, version 0.4
[ 50.457] (II) FBTURBO(0): FBIOBLANK: Invalid argument (Screen blanking not supported by kernel - disabling)
[ 50.475] (II) FBTURBO(0): using backing store heuristics
[ 50.487] (II) FBTURBO(0): can't load 'g2d_23' kernel module
[ 50.487] (II) FBTURBO(0): failed to enable the use of sunxi display controller
[ 50.487] (II) FBTURBO(0): No sunxi-g2d hardware detected (check /dev/disp and /dev/g2d)
[ 50.487] (II) FBTURBO(0): G2D hardware acceleration can't be enabled
[ 50.487] (II) FBTURBO(0): enabled VFP/NEON optimizations
[ 50.487] (==) FBTURBO(0): Backing store enabled
[ 50.495] (==) FBTURBO(0): DPMS enabled
[ 50.495] (II) FBTURBO(0): failed to enable hardware cursor
[ 50.495] (II) FBTURBO(0): no 3D acceleration because the driver has been compiled without libUMP
[ 50.495] (II) FBTURBO(0): if this is wrong and needs to be fixed, please check ./configure log
[ 50.496] (II) Initializing extension Generic Event Extension
[ 50.497] (II) Initializing extension SHAPE
[ 50.498] (II) Initializing extension MIT-SHM
[ 50.499] (II) Initializing extension XInputExtension
[ 50.504] (II) Initializing extension XTEST
[ 50.505] (II) Initializing extension BIG-REQUESTS
[ 50.506] (II) Initializing extension SYNC
[ 50.507] (II) Initializing extension XKEYBOARD
[ 50.508] (II) Initializing extension XC-MISC
[ 50.509] (II) Initializing extension SECURITY
[ 50.510] (II) Initializing extension XFIXES
[ 50.511] (II) Initializing extension RENDER
[ 50.512] (II) Initializing extension RANDR
[ 50.514] (II) Initializing extension COMPOSITE
[ 50.516] (II) Initializing extension DAMAGE
[ 50.517] (II) Initializing extension MIT-SCREEN-SAVER
[ 50.517] (II) Initializing extension DOUBLE-BUFFER
[ 50.518] (II) Initializing extension RECORD
[ 50.519] (II) Initializing extension DPMS
[ 50.520] (II) Initializing extension Present
[ 50.521] (II) Initializing extension DRI3
[ 50.521] (II) Initializing extension X-Resource
[ 50.522] (II) Initializing extension XVideo
[ 50.523] (II) Initializing extension XVideo-MotionCompensation
[ 50.523] (II) Initializing extension SELinux
[ 50.523] (II) SELinux: Disabled on system
[ 50.523] (II) Initializing extension GLX
[ 50.524] (II) AIGLX: Screen 0 is not DRI2 capable
[ 51.762] (II) IGLX: Loaded and initialized swrast
[ 51.762] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 51.762] (II) Initializing extension XFree86-VidModeExtension
[ 51.763] (II) Initializing extension XFree86-DGA
[ 51.764] (II) Initializing extension XFree86-DRI
[ 51.767] (II) Initializing extension DRI2
[ 52.058] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/event4)
[ 52.058] (**) ADS7846 Touchscreen: Applying InputClass "evdev touchscreen catchall"
[ 52.058] (**) ADS7846 Touchscreen: Applying InputClass "libinput touchscreen catchall"
[ 52.058] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 52.058] (**) ADS7846 Touchscreen: Applying InputClass "Touch rotation"
[ 52.058] (II) LoadModule: "evdev"
[ 52.059] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 52.065] (II) Module evdev: vendor="X.Org Foundation"
[ 52.065] compiled for 1.20.3, module version = 2.10.6
[ 52.065] Module class: X.Org XInput Driver
[ 52.065] ABI class: X.Org XInput driver, version 24.1
[ 52.065] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 52.065] (**) ADS7846 Touchscreen: always reports core events
[ 52.065] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/event4"
[ 52.065] (--) evdev: ADS7846 Touchscreen: Vendor 0 Product 0x1ea6
[ 52.065] (--) evdev: ADS7846 Touchscreen: Found absolute axes
[ 52.065] (--) evdev: ADS7846 Touchscreen: Found x and y absolute axes
[ 52.065] (--) evdev: ADS7846 Touchscreen: Found absolute touchscreen
[ 52.065] (**) Option "SwapAxes" "1"
[ 52.065] (II) evdev: ADS7846 Touchscreen: Configuring as touchscreen
[ 52.065] (**) evdev: ADS7846 Touchscreen: YAxisMapping: buttons 4 and 5
[ 52.065] (**) evdev: ADS7846 Touchscreen: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 52.065] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f204000.spi/spi_master/spi0/spi0.1/input/input4/event4"
[ 52.065] (II) XINPUT: Adding extended input device "ADS7846 Touchscreen" (type: TOUCHSCREEN, id 6)
[ 52.066] (II) evdev: ADS7846 Touchscreen: initialized for absolute axes.
[ 52.066] (**) ADS7846 Touchscreen: (accel) keeping acceleration scheme 1
[ 52.066] (**) ADS7846 Touchscreen: (accel) acceleration profile 0
[ 52.066] (**) ADS7846 Touchscreen: (accel) acceleration factor: 2.000
[ 52.066] (**) ADS7846 Touchscreen: (accel) acceleration threshold: 4
[ 52.066] (**) Option "TransformationMatrix" "-1 0 1 0 -1 1 0 0 1"
[ 52.068] (II) config/udev: Adding input device ADS7846 Touchscreen (/dev/input/mouse1)
[ 52.068] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 52.069] (**) ADS7846 Touchscreen: Applying InputClass "calibration"
[ 52.069] (II) Using input driver 'evdev' for 'ADS7846 Touchscreen'
[ 52.069] (**) ADS7846 Touchscreen: always reports core events
[ 52.069] (**) evdev: ADS7846 Touchscreen: Device: "/dev/input/mouse1"
[ 52.069] (EE) evdev: ADS7846 Touchscreen: Unable to query fd: Inappropriate ioctl for device
[ 52.170] (EE) PreInit returned 2 for "ADS7846 Touchscreen"
[ 52.170] (II) UnloadModule: "evdev"
[ 52.173] (II) config/udev: Adding input device Mini Keyboard (/dev/input/event0)
[ 52.173] (**) Mini Keyboard: Applying InputClass "evdev keyboard catchall"
[ 52.173] (**) Mini Keyboard: Applying InputClass "libinput keyboard catchall"
[ 52.173] (II) LoadModule: "libinput"
[ 52.173] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 52.202] (II) Module libinput: vendor="X.Org Foundation"
[ 52.202] compiled for 1.20.3, module version = 0.28.2
[ 52.202] Module class: X.Org XInput Driver
[ 52.202] ABI class: X.Org XInput driver, version 24.1
[ 52.202] (II) Using input driver 'libinput' for ' Mini Keyboard'
[ 52.202] (**) Mini Keyboard: always reports core events
[ 52.202] (**) Option "Device" "/dev/input/event0"
[ 52.202] (**) Option "_source" "server/udev"
[ 52.226] (II) event0 - Mini Keyboard: is tagged by udev as: Keyboard
[ 52.226] (II) event0 - Mini Keyboard: device is a keyboard
[ 52.227] (II) event0 - Mini Keyboard: device removed
[ 52.280] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:1997:2433.0001/input/input0/event0"
[ 52.280] (II) XINPUT: Adding extended input device " Mini Keyboard" (type: KEYBOARD, id 7)
[ 52.280] (**) Option "xkb_model" "pc105"
[ 52.280] (**) Option "xkb_layout" "us"
[ 52.288] (II) event0 - Mini Keyboard: is tagged by udev as: Keyboard
[ 52.288] (II) event0 - Mini Keyboard: device is a keyboard
[ 52.293] (II) config/udev: Adding input device Mini Keyboard Mouse (/dev/input/event1)
[ 52.293] (**) Mini Keyboard Mouse: Applying InputClass "evdev pointer catchall"
[ 52.293] (**) Mini Keyboard Mouse: Applying InputClass "libinput pointer catchall"
[ 52.293] (II) Using input driver 'libinput' for ' Mini Keyboard Mouse'
[ 52.293] (**) Mini Keyboard Mouse: always reports core events
[ 52.293] (**) Option "Device" "/dev/input/event1"
[ 52.293] (**) Option "_source" "server/udev"
[ 52.300] (II) event1 - Mini Keyboard Mouse: is tagged by udev as: Mouse
[ 52.301] (II) event1 - Mini Keyboard Mouse: device is a pointer
[ 52.301] (II) event1 - Mini Keyboard Mouse: device removed
[ 52.340] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input1/event1"
[ 52.340] (II) XINPUT: Adding extended input device " Mini Keyboard Mouse" (type: MOUSE, id 8)
[ 52.341] (**) Option "AccelerationScheme" "none"
[ 52.341] (**) Mini Keyboard Mouse: (accel) selected scheme none/0
[ 52.341] (**) Mini Keyboard Mouse: (accel) acceleration factor: 2.000
[ 52.341] (**) Mini Keyboard Mouse: (accel) acceleration threshold: 4
[ 52.348] (II) event1 - Mini Keyboard Mouse: is tagged by udev as: Mouse
[ 52.349] (II) event1 - Mini Keyboard Mouse: device is a pointer
[ 52.352] (II) config/udev: Adding input device Mini Keyboard Mouse (/dev/input/mouse0)
[ 52.352] (II) No input driver specified, ignoring this device.
[ 52.352] (II) This device may have been added with another device file.
[ 52.355] (II) config/udev: Adding input device Mini Keyboard System Control (/dev/input/event2)
[ 52.355] (**) Mini Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 52.355] (**) Mini Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 52.355] (II) Using input driver 'libinput' for ' Mini Keyboard System Control'
[ 52.355] (**) Mini Keyboard System Control: always reports core events
[ 52.355] (**) Option "Device" "/dev/input/event2"
[ 52.355] (**) Option "_source" "server/udev"
[ 52.363] (II) event2 - Mini Keyboard System Control: is tagged by udev as: Keyboard
[ 52.363] (II) event2 - Mini Keyboard System Control: device is a keyboard
[ 52.364] (II) event2 - Mini Keyboard System Control: device removed
[ 52.400] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input2/event2"
[ 52.400] (II) XINPUT: Adding extended input device " Mini Keyboard System Control" (type: KEYBOARD, id 9)
[ 52.400] (**) Option "xkb_model" "pc105"
[ 52.400] (**) Option "xkb_layout" "us"
[ 52.408] (II) event2 - Mini Keyboard System Control: is tagged by udev as: Keyboard
[ 52.408] (II) event2 - Mini Keyboard System Control: device is a keyboard
[ 52.412] (II) config/udev: Adding input device Mini Keyboard Consumer Control (/dev/input/event3)
[ 52.412] (**) Mini Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.413] (**) Mini Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.413] (II) Using input driver 'libinput' for ' Mini Keyboard Consumer Control'
[ 52.413] (**) Mini Keyboard Consumer Control: always reports core events
[ 52.413] (**) Option "Device" "/dev/input/event3"
[ 52.413] (**) Option "_source" "server/udev"
[ 52.420] (II) event3 - Mini Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 52.420] (II) event3 - Mini Keyboard Consumer Control: device is a keyboard
[ 52.421] (II) event3 - Mini Keyboard Consumer Control: device removed
[ 52.480] (II) libinput: Mini Keyboard Consumer Control: needs a virtual subdevice
[ 52.480] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input3/event3"
[ 52.480] (II) XINPUT: Adding extended input device " Mini Keyboard Consumer Control" (type: MOUSE, id 10)
[ 52.480] (**) Option "AccelerationScheme" "none"
[ 52.480] (**) Mini Keyboard Consumer Control: (accel) selected scheme none/0
[ 52.480] (**) Mini Keyboard Consumer Control: (accel) acceleration factor: 2.000
[ 52.480] (**) Mini Keyboard Consumer Control: (accel) acceleration threshold: 4
[ 52.488] (II) event3 - Mini Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 52.488] (II) event3 - Mini Keyboard Consumer Control: device is a keyboard
[ 52.504] (**) Mini Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 52.505] (**) Mini Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 52.505] (II) Using input driver 'libinput' for ' Mini Keyboard Consumer Control'
[ 52.505] (**) Mini Keyboard Consumer Control: always reports core events
[ 52.505] (**) Option "Device" "/dev/input/event3"
[ 52.505] (**) Option "_source" "_driver/libinput"
[ 52.505] (II) libinput: Mini Keyboard Consumer Control: is a virtual subdevice
[ 52.505] (**) Option "config_info" "udev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:1997:2433.0002/input/input3/event3"
[ 52.505] (II) XINPUT: Adding extended input device " Mini Keyboard Consumer Control" (type: KEYBOARD, id 11)
[ 52.505] (**) Option "xkb_model" "pc105"
[ 52.505] (**) Option "xkb_layout" "us"
99-fbturbo.conf
# This is a minimal sample config file, which can be copied to
# /etc/X11/xorg.conf in order to make the Xorg server pick up
# and load xf86-video-fbturbo driver installed in the system.
# When troubleshooting, check /var/log/Xorg.0.log for the debugging
# output and error messages.
#The driver is made by Waveshare&Spotpear
# Run "man fbturbo" to get additional information about the extra
# configuration options for tuning the driver.
Section "Device"
Identifier "Allwinner A10/A13 FBDEV"
Driver "fbturbo"
Option "fbdev" "/dev/fb0"
EndSection
99-calibration.conf
Section "InputClass"
Identifier "calibration"
MatchProduct "ADS7846 Touchscreen"
Option "Calibration" "3932 300 294 3801"
Option "EmulateThirdButton" "1"
Option "EmulateThirdButtonTimeout" "1000"
Option "EmulateThirdButtonMoveThreshold" "300"
EndSection
(reformatted by @gkkpch for readability)
