arus12
September 25, 2021, 10:47pm
1
128x32 Oled for Volumio (Raspberry Pi) ver 1.0 beta
This display (SSD1305 controller) is not supported by default by Volumio.
This program displays the main data of h ttp://volumio.local/api/v1/getState (status, duration/seek, volume, artist, title).
The “oled.c” program code I wrote is free to use based on the ht tp://www.waveshare.com/w/upload/c/c5/2.23inch-OLED-HAT-Code.7z demo.
Display type: Waveshare 2.23" OLED HAT, 128 x 32 pixel
h ttps://www.waveshare.com/wiki/2.23inch_OLED_HAT
C program code using the following libraries:
h ttp://www.airspayce.com/mikem/bcm2835/
=> Downloadable program and C source code: oled.zip
h ttp://users.atw.hu/oled/oled.zip
http://oled.atw.hu/
Brief information:
1.0 beta, works but not perfect!
SPI must be enabled (sudo raspi-config)
the program is in C language (not C ++!)
bcm2835-1.69.tar.gz must be installed
libcurl must be installed
Install GCC for C compilation
always run with sudo: sudo ./oled
must be loaded into systemd for automatic startup:
[Unit]
Description=oled service
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/sudo /home/volumio/oled
Restart=always
[Install]
WantedBy=multi-user.target
arus12
October 5, 2021, 3:56pm
3
Ver 1.22 beta:
some bug fixes
smaller status line on top
playtime progress line
text paging (if artist or title more than 21 letter)
display track technical data for short time - after play
(Picture from finished, boxed project.)
arus12
October 8, 2021, 9:15am
4
Ver 1.24 beta:
some bug fixes
display track position
character redesigner util available (for ssd1305.h)
Latest version available: oled.atw.hu
arus12
July 25, 2022, 9:31am
6
Ver 1.26 beta2:
Modified version also available in zip file: http://oled.atw.hu/
first line: small numbers redesigned
first line: no volume display, instead there is playback mode and track number
arus12
July 30, 2022, 6:34pm
7
Ver 1.26 beta2:
Program & source code:
oled_b2.zip (68.4 KB)
arus12
December 6, 2022, 2:45pm
8
Ver 1.27 beta
ver_1_27_beta.zip (68.6 KB)
arus12
January 2, 2023, 4:21pm
9
Ver 1.28 beta:
Display volume and mute in bottom line (removed from right upper corner)
ver_1_28_beta.zip (69.2 KB)
The data shown on the display:
Local IP address (at startup)
Play mode (stop/play/pause)
Track time (duration, percent line)
Repeat mode (1, all, shuffle)
Track number
Artist, title
Media format and quality (after play a track)
Volume (if changed, mute too)
arus12
April 19, 2023, 2:19pm
10
Ver 1.32 beta:
Text scroll (Artist, Title) function
Scroll on/off: down volume to 0 (not mute!) and wait 5 sec: scroll off (or on). Up the volume.
oled_v132beta.zip (70.2 KB)
