Hi, I downloaded a .wav file and when playing it, only a buzzing noise (white noise) is heard.
In VLC it reproduces perfectly, it tells me that it is this format:
Codec: DTS Audio (dts)
Type: Audio
Channels: 3F2M / LFE
Sample rate: 44100 Hz
Bits per sample: 32
I converted it to Flac with Foobar but I do not think it maintains the quality of the original.
Is there any way to reproduce it in Volumio? I am doing something wrong?
A link to the file might be useful??
http://camelotmascotas.com.ar/Volumio_wav/
Tell me if you can download it.
Yep it does download, and yes it does produce white noise. I think it is an wav encapsulated DTS file, and I thought (but might be wrong) that mpd plays such files, so presumably Volumio should do so too. Someone else was referring to this back in February fail-decode-dts-wav-format-t11788.html.
Nice track btw
