Fresh and new…
Let me know what do you guys think… If this is good I’ll publish…
2 news on that… Now it can read UPNP shares (just update the DB and your UPNP shared music will magically appear…) and you can control with upnp\dlna… Suggest to use bubbleupnp, its just amazing
Mmhhh the xmos problems is not resolved.
It work only with the workaround I am not able to reboot or power off with software because in this case I have to reformat and reinstall Volumio in the microsd.
Usb hardisk - Now I have in loop the database and only see a little part of my music files.
Bubble upnp don’t show volumio.
Now no nas access.
Positive:
The sound quality seems to my ears more enjoable than the earlier versions.
But in few words… a lot of problem.
I return to 1.0
Dr165 are you able to use bubbleupnp and listening music in udoo?
I was able to render the music only in my phone and not in udoo.
I have only the volumio library not option to render in udoo.
I have tried 1.3 version…but still problems to get sound from my USB Audiolab MDAC (like with Volumio 1.0)
Still I get MPD error below (with log_level = Verbose)
Apr 27 18:53 : alsa_output: opened hw:2,0 type=HW
Apr 27 18:53 : alsa_output: format=S24_3LE (Signed 24 bit Little Endian in 3bytes)
Apr 27 18:53 : alsa_output: buffer: size=90..174762 time=2040..3962858
Apr 27 18:53 : alsa_output: period: size=45..87381 time=1020..1981429
Apr 27 18:53 : alsa_output: default period_time = buffer_time/4 = 500000/4 = 125000
Apr 27 18:53 : client: [10] process command "status"
Apr 27 18:53 : alsa_output: Failed to open "Output" [alsa]: Error opening ALSA device "hw:2,0" (snd_pcm_hw_params): Broken pipe
Apr 27 18:53 : output: Failed to open audio output
Apr 27 18:53 : player: problems opening audio device while playing "http://89.16.185.174:8003/stream"
Additionally…dmesg shows the following:
205.450658] 4:2:1: cannot get freq at ep 0x1
[ 205.455323] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 205.465404] 4:2:1: cannot get freq at ep 0x1
[ 205.469910] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 205.479652] 4:2:1: cannot get freq at ep 0x1
[ 205.484132] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 205.494030] 4:2:1: cannot get freq at ep 0x1
[ 205.498460] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 205.508276] 4:2:1: cannot get freq at ep 0x1
[ 205.512681] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 241.239671] 4:2:1: cannot get freq at ep 0x1
[ 241.244195] cannot submit datapipe for urb 0, error -28: not enough bandwidth
[ 241.254178] 4:2:1: cannot get freq at ep 0x1
I have the DB update issue as well, otherwise everything is good. When scanning the files on Samba share it loops non-stop and on every reboot the DB is empty.
Origin of my update database issue:
Same music downloaded from qobuz have this format:
First album
01 01 track name
01 02 track name
01 03 track name
01 04 track name
01 05…
Second album
02 01 track name
02 02 track name
02 03 track name
02 04 …
third album
03 01 track name
03 02 track name
03 03 track name
03 04 …
All the flac files was in one folder
When I deleted or changed this format no more update database issue.
