yes, I have an SD with volumio 2.777 and it’s working, screen and touch.
I don’t know. It’s from Volumio 2.777 install in option miscellanea.
Yes. When I tried to install the touchscreen in Volumio 3, I follow the step by step guide from the theard mentioned above: Fresh volumio 3 → Install Touch Dsiplay and enabled → Via ssh the steps from the thread mentioned.
The steps are the same than Volumio 2.777, but when enter de line “sudo nano /usr/share/X11/xorg.conf.d/99-fbturbo.conf”, says that fil not exist. Copy from my another setup and follow. The rest no problem.
However, when reboot, the screen is complete black and show nothing and send this message
cat /var/log/Xorg.0.log
[ 47.335]
X.Org X Server 1.20.4
[ 47.336] Build Operating System: Linux 5.10.17-v8+ aarch64 Raspbian
[ 47.336] Current Operating System: Linux volumio 5.4.83-v7+ #1379 SMP Mon Dec 14 13:08:57 GMT 2020 armv7l
[ 47.336] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=640 bcm2708_fb.fbheight=480 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 loglevel=0
[ 47.336] Build Date: 19 April 2021 03:23:36PM
[ 47.336] xorg-server 2:1.20.4-1+rpt3+deb10u3 (Debian -- Support)
[ 47.336] Current version of pixman: 0.36.0
[ 47.336] Before reporting problems, check http://wiki.x.org
[ 47.336] Markers: (–) probed, () from config file, (==) default setting,
[ 47.337] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Jan 3 02:56:39 2022
[ 47.349] (==) Using config directory: “/etc/X11/xorg.conf.d”
[ 47.349] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 47.358] (==) No Layout section. Using the first Screen section.
[ 47.358] (==) No screen section available. Using defaults.
[ 47.358] () |–>Screen “Default Screen Section” (0)
[ 47.358] () | |–>Monitor “”
[ 47.366] (==) No device specified for screen “Default Screen Section”.
Using the first device section listed.
[ 47.366] () | |–>Device “Allwinner A10/A13/A20 FBDEV”
[ 47.366] (==) No monitor specified for screen “Default Screen Section”.
[ 47.366] (==) Automatically adding devices
[ 47.366] (==) Automatically enabling devices
[ 47.366] (==) Automatically adding GPU devices
[ 47.373] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 47.375] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 47.375] Entry deleted from font path.
[ 47.377] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 47.378] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 47.378] (II) The server relies on udev to provide the list of input devices.
[ 47.378] (II) Loader magic: 0x1fdf80
[ 47.378] (II) Module ABI versions:
[ 47.378] X.Org ANSI C Emulation: 0.4
[ 47.378] X.Org Video Driver: 24.0
[ 47.378] X.Org XInput driver : 24.1
[ 47.378] X.Org Server Extension : 10.0
[ 47.382] (–) using VT number 2
[ 47.382] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 47.383] (II) no primary bus or device found
[ 47.383] (II) LoadModule: “glx”
[ 47.389] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 47.483] (II) Module glx: vendor=“X.Org Foundation”
[ 47.483] compiled for 1.20.4, module version = 1.0.0
[ 47.483] ABI class: X.Org Server Extension, version 10.0
[ 47.483] (II) LoadModule: “fbturbo”
[ 47.487] (WW) Warning, couldn’t open module fbturbo
[ 47.487] (EE) Failed to load module “fbturbo” (module does not exist, 0)
[ 47.487] (EE) No drivers available.
[ 47.487] (EE)
Fatal server error:
[ 47.488] (EE) no screens found(EE)
[ 47.488] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 47.488] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 47.488] (EE)
[ 47.488] (EE) Server terminated with error (1). Closing log file.
