Hi balbuze,
here is my report.
hardware : rpi3 & HifiBerry Digi
software : Volumio 2.323
plugins : GPIO Buttons
Todays test results:
Volumio booted -> same as before: startup sound = yes / music = no
Opened ssh ->
volumio@volumio:~$ systemctl status volbinauralfilter -l
? volbinauralfilter.service - alsaloop for volbinauralfilter
Loaded: loaded (/etc/systemd/system/volbinauralfilter.service; disabled)
Active: failed (Result: start-limit) since Wed 2017-11-22 18:47:08 UTC; 15min ago
Process: 1097 ExecStart=/usr/bin/alsaloop -C plughw:Loopback,1 -P outbauer -t 8000 0 -w 500 (code=exited, status=1/FAILURE)
Main PID: 1097 (code=exited, status=1/FAILURE)
Nov 22 18:47:08 volumio volumio[1097]: Loopback initialization failure.
Nov 22 18:47:08 volumio systemd[1]: volbinauralfilter.service: main process exited, code=exited, status=1/FAILURE
Nov 22 18:47:08 volumio systemd[1]: Unit volbinauralfilter.service entered failed state.
Nov 22 18:47:08 volumio systemd[1]: volbinauralfilter.service holdoff time over, scheduling restart.
Nov 22 18:47:08 volumio systemd[1]: Stopping alsaloop for volbinauralfilter…
Nov 22 18:47:08 volumio systemd[1]: Starting alsaloop for volbinauralfilter…
Nov 22 18:47:08 volumio systemd[1]: volbinauralfilter.service start request repeated too quickly, refusing to start.
Nov 22 18:47:08 volumio systemd[1]: Failed to start alsaloop for volbinauralfilter.
Because it was obviously not running ->
volumio@volumio:~$ systemctl start volbinauralfilter
Active: failed (Result: start-limit) since Wed 2017-11-22 19:05:38 UTC; 12s ago
Process: 2373 ExecStart=/usr/bin/alsaloop -C plughw:Loopback,1 -P outbauer -t 80000 -w 500 (code=exited, status=1/FAILURE)
Main PID: 2373 (code=exited, status=1/FAILURE)
Nov 22 19:05:38 volumio systemd[1]: volbinauralfilter.service: main process exited, code=exited, status=1/FAILURE
Nov 22 19:05:38 volumio systemd[1]: Unit volbinauralfilter.service entered failed state.
Nov 22 19:05:38 volumio systemd[1]: volbinauralfilter.service holdoff time over, scheduling restart.
Nov 22 19:05:38 volumio systemd[1]: Stopping alsaloop for volbinauralfilter…
Nov 22 19:05:38 volumio systemd[1]: Starting alsaloop for volbinauralfilter…
Nov 22 19:05:38 volumio systemd[1]: volbinauralfilter.service start request repeated too quickly, refusing to start.
Nov 22 19:05:38 volumio systemd[1]: Failed to start alsaloop for volbinauralfilter.
Although I played a track -> no sound
Please find attached the log about the start of Volumio (zipped because the forum software did not allow .txt and .log files)
Cheers
Pirx
Volumio log.zip (4.56 KB)
