I really liked Volumio2 after testing the SD Image based installation so I decided to try to install it on a “Jessie Lite” raspberry 3 image.
I think I managed to solve “most” issues of the installation from scratch, I spent a few days scratching my head to understand what is needed or not from the “build.sh” script and the following script.
Now I can start the daemon volumio2 and get the begin of a webpage…
But I don’t have any knowledge on Node JS and I get a page with the background of volumio2 but it is stuck as if node was not working.
I have nothing in the logs (I can publish them).
Anyone could led me in the right directory to how complete my installation or what can go wrong ?
Thanks in advance.
JC
PS: I can post the webpage image too…
I have tried to install other packages (softwares) on top of volumio Image but I found it difficult so I wanted to do it the other way, install volumio (and understand how it is installed) then install other softwares (openhab, python scripts, etc…)
I’ll try tonite the NAT the other way around, so I need :
a NAT from 80 -> 3000
a NAT from 3000 -> 80 ?
This is what I did, before re-routing port 80 -> 3000, I had no answer at all.
Now I can see the “volumio” background page, if it is like “node JS” and something else was not responding
I have a screen with the background and a “loop” waiting for an answer…
Volumio backup receive the update from the MPD daemon as when controlled from “MP Droid” I can see the updates in the log. This is just the UI which seems to be blocked
