Hi and thanks for this really nice piece of software!
I am wondering how one can have the covers show in clients like MPDroid, MPad, Cantata…
With volumio 1.55 what I did is simply create a symlink for music folder to www folder so that clients could fetch the cover.jpg directly.
I am new to node.js so I don’t understand completely what’s going on but form what I’ve seen there is an albumart plugin which expects a path query to retrieve the cover.
I have been unsuccessful at making this work in my clients. I am trying by setting the fetch url to volumio.local/albumart?path=
But somehow they probably fail to properly input the path.
Would you be kind to direct me how I can resolve this?
Did you try to just put http://volumio.local/albumart? that is what I see as the location of the albumart on my volumio 2 version.
If that does not work, are you positive that the volumio.local hostname is properly undestood by your device? Remember that android devices (as an example) does not have system-wide zeroconf lookup, but a specific app might or might not have it implemented.
I am not sure what you mean by the folder having to be shared but if you mean access rights, it is not a problem. I had this working on volumio 1.55 which has a conventional web server just serving the files statically.
Play a track in Volumio. On the album art with right click select display image in a new window or tab or image properties.
Now you have the full path to the image.
ex : 192.168.0.17/albumart?web=Arno/B … 0Hero.flac
