Hi everyone,
i’m using Volumio (latest build) on my Lenovo Miix 320, and it works like a charm.
Only “problem” is, that the display is not in landscape mode, it’s in portrait mode.
That means it has to be rotated 90° clockwise.
Anyone knows how to do this?
Perhaps it can be put as an option in the appearance section in future builds.
Thx, Joe.
Hello. Did you manage to find a solution having the same problem.
Wheaten
November 22, 2022, 1:22pm
3
Using command line to rotate video display:
From the command prompt type:
xrandr -o left
xrandr -o right
xrandr -o normal
xrandr -o inverted
Adding “display_rotate=x” to /boot/userconfig.txt and reboot to change the video display rotation.
(Where x = 0 (normal), 1 is 90 degree, 2 is 180 degree, 3 is 270 degree.)
