Volumio X86: Rotate LOADING / SPLASH screen..?
Volumio X86 3.812
Intel NUC D34010WYK i3 / 8GB
Khadas Tone2 DAC
WaveShare 400 X 1280 HDMI screen
Hello Volumioers
I’ve got the display rotated (xrandr setting in in /etc/X11/Xsession.d/45custom_xrandr-settings) and I’ve got the touch rotated (this screen has a very handy ‘rotate touch’ button on the back) and everything is wonderful (even the touch - loving it)…but I’m wondering if there’s a way to rotate the volumio loading / splash screen? yes, it’s only displayed for maybe 5 seconds…but…it’s wrong. is there a way to make it right ?
Alastair
@nerd is working on this feature within the bookworm version, currently in Alpha state.
Please feel free to join.
Not sure why you decided to rotate the screen using xrandr, instead of doing this in the plugin?
The ‘now playing’ plugin on x86 has a screen rotate setting… ?
the Touch display plugin has this.
I didn’t see a touch plugin in the list. OK thanks, I shall investigate.
Sorry my bad. Didn’t see it’s a x86. Was distracted by the WS screen, which runs here on my rPi.
Nope there is indeed no Touch Display plugin.
For the x86 you did it correct.
Ah great OK - Ill join the Alpha!
Cheers
Alastair
