Hi everyone! Sorry for my English
I replaced the raspberry pi3b (dead) with a new PC standard to dedicate to Volumio but there are big problems with VolumioX86.
Pc is Asrock J3455-ITX Mini ITX - SSD - 8Gb Ram 1866
I had great difficulty with the installation and I had to flash the HDD because from Pendrive the installation stopped, but in the end I succeeded and the system starts up.
However:
1 - Works only with DHCP - If I set static IP Volumio does not connect to the internet and does not see the Plugins - But it works ssh and network view
2 - Very very slow boot - with this type of PC and SSD disk it should be very fast
3 - The display of the screen connected to the PC is not fast (this is not a big problem - I will use Volumio without monitor)
I enclose some results, hoping that some genius can help me.
LSHW Result
lshw
volumiox86
description: Computer
width: 32 bits
capabilities: smbios-3.0
*-core
description: Motherboard
physical id: 0
*-memory
description: System memory
physical id: 0
*-cpu
product: Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
vendor: Intel Corp.
physical id: 1
bus info: cpu@0
version: 6.12.9
serial: 0005-06C9-0000-0000-0000-0000
capacity: 1501MHz
width: 64 bits
capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe nx pdpe1gb rdtscp x86-64 constant_tsc arch_perfmon pebs bts xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm 3dnowprefetch ida arat pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust smep erms mpx rdseed smap clflushopt xsaveopt xsavec xgetbv1 cpufreq
configuration: id=0
*-logicalcpu:0
description: Logical CPU
physical id: 0.1
width: 64 bits
capabilities: logical
*-logicalcpu:1
physical id: 0.2
width: 64 bits
*-logicalcpu:2
physical id: 0.3
width: 64 bits
*-logicalcpu:3
physical id: 0.4
width: 64 bits
*-logicalcpu:4
physical id: 0.5
width: 64 bits
*-logicalcpu:5
physical id: 0.6
width: 64 bits
*-logicalcpu:6
physical id: 0.7
width: 64 bits
*-logicalcpu:7
physical id: 0.8
width: 64 bits
*-logicalcpu:8
physical id: 0.9
width: 64 bits
*-logicalcpu:9
physical id: 0.a
width: 64 bits
*-logicalcpu:10
physical id: 0.b
width: 64 bits
*-logicalcpu:11
physical id: 0.c
width: 64 bits
*-logicalcpu:12
physical id: 0.d
width: 64 bits
*-logicalcpu:13
physical id: 0.e
width: 64 bits
*-logicalcpu:14
physical id: 0.f
width: 64 bits
*-logicalcpu:15
physical id: 0.10
width: 64 bits
*-logicalcpu:16
physical id: 0.11
width: 64 bits
*-logicalcpu:17
physical id: 0.12
width: 64 bits
*-logicalcpu:18
physical id: 0.13
width: 64 bits
*-logicalcpu:19
physical id: 0.14
width: 64 bits
*-logicalcpu:20
physical id: 0.15
width: 64 bits
*-logicalcpu:21
physical id: 0.16
width: 64 bits
*-logicalcpu:22
physical id: 0.17
width: 64 bits
*-logicalcpu:23
physical id: 0.18
width: 64 bits
*-logicalcpu:24
physical id: 0.19
width: 64 bits
*-logicalcpu:25
physical id: 0.1a
width: 64 bits
*-logicalcpu:26
physical id: 0.1b
width: 64 bits
*-logicalcpu:27
physical id: 0.1c
width: 64 bits
*-logicalcpu:28
physical id: 0.1d
width: 64 bits
*-logicalcpu:29
physical id: 0.1e
width: 64 bits
*-logicalcpu:30
physical id: 0.1f
width: 64 bits
*-logicalcpu:31
physical id: 0.20
width: 64 bits
*-pci
description: Host bridge
product: Intel Corporation
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 0b
width: 32 bits
clock: 33MHz
*-display UNCLAIMED
description: VGA compatible controller
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list
configuration: latency=0
resources: memory:90000000-90ffffff memory:80000000-8fffffff ioport:f000(size=64)
*-multimedia
description: Audio device
physical id: e
bus info: pci@0000:00:0e.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=snd_hda_intel latency=0
resources: irq:127 memory:91310000-91313fff memory:91000000-910fffff
*-communication UNCLAIMED
description: Communication controller
physical id: f
bus info: pci@0000:00:0f.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list
resources: memory:9131b000-9131bfff
*-storage
description: SATA controller
physical id: 12
bus info: pci@0000:00:12.0
version: 0b
width: 32 bits
clock: 66MHz
capabilities: storage msi pm ahci_1.0 bus_master cap_list
configuration: driver=ahci latency=0
resources: irq:124 memory:91314000-91315fff memory:91318000-913180ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:91317000-913177ff
*-pci:0
description: PCI bridge
physical id: 13
bus info: pci@0000:00:13.0
version: fb
width: 32 bits
clock: 33MHz
capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:120 ioport:e000(size=4096) memory:91200000-912fffff
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
logical name: eth0
version: 11
serial: 70:85:c2:80:48:07
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-2_0.0.1 02/06/13 ip=192.168.1.100 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:128 ioport:e000(size=256) memory:91204000-91204fff memory:91200000-91203fff
*-pci:1
physical id: 13.1
bus info: pci@0000:00:13.1
version: fb
width: 32 bits
clock: 33MHz
resources: irq:121
*-pci:2
physical id: 13.2
bus info: pci@0000:00:13.2
version: fb
width: 32 bits
clock: 33MHz
resources: irq:122 ioport:d000(size=4096) memory:91100000-911fffff
*-storage
product: ASM1062 Serial ATA Controller
vendor: ASMedia Technology Inc.
physical id: 0
bus info: pci@0000:03:00.0
version: 02
width: 32 bits
clock: 33MHz
capabilities: storage msi pm pciexpress ahci_1.0 bus_master cap_list
resources: irq:125 ioport:d050(size=8) ioport:d040(size=4) ioport:d030(size=8) ioport:d020(size=4) ioport:d000(size=32) memory:91100000-911001ff
*-pci:3
physical id: 13.3
bus info: pci@0000:00:13.3
version: fb
width: 32 bits
clock: 33MHz
resources: irq:123
*-usb
description: USB controller
physical id: 15
bus info: pci@0000:00:15.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: pm msi xhci bus_master cap_list
configuration: driver=xhci_hcd latency=0
resources: irq:126 memory:91300000-9130ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 3.18.25 xhci-hcd
physical id: 0
bus info: usb@2
logical name: usb2
version: 3.18
capabilities: usb-3.00
configuration: driver=hub slots=7 speed=5000Mbit/s
*-usbhost:1
physical id: 1
bus info: usb@1
logical name: usb1
version: 3.18
capabilities: usb-2.00
configuration: driver=hub slots=8 speed=480Mbit/s
*-usb
description: Mouse
product: USB-PS/2 Optical Mouse
vendor: Logitech
physical id: 2
bus info: usb@1:2
version: 11.10
configuration: driver=usbhid maxpower=98mA speed=2Mbit/s
*-isa
description: ISA bridge
physical id: 1f
bus info: pci@0000:00:1f.0
version: 0b
width: 32 bits
clock: 33MHz
capabilities: isa bus_master
*-serial UNCLAIMED
description: SMBus
physical id: 1f.1
bus info: pci@0000:00:1f.1
version: 0b
width: 64 bits
clock: 33MHz
resources: memory:91316000-913160ff ioport:f040(size=32)
*-scsi
physical id: 2
logical name: scsi0
capabilities: emulated
*-disk
description: ATA Disk
product: Crucial_CT120M50
physical id: 0.0.0
bus info: scsi@0:0.0.0
logical name: /dev/sda
version: MU05
serial: 14020961F919
capabilities: gpt-1.00 partitioned partitioned:gpt
configuration: ansiversion=5 guid=8f9688b4-2dff-40a6-adce-59cde0b00d41 logicalsectorsize=512 sectorsize=4096
*-volume:0
description: Windows FAT volume
vendor: SYSLINUX
physical id: 1
bus info: scsi@0:0.0.0,1
logical name: /dev/sda1
logical name: /boot
version: FAT32
serial: f7e8-8f97
capacity: 486MiB
capabilities: boot precious readonly hidden nomount fat initialized
configuration: FATs=2 filesystem=fat label=volumioboot mount.fstype=vfat mount.options=rw,nosuid,nodev,noexec,relatime,fmask=0111,dmask=0000,allow_utime=0022,codepage=437,iocharset=utf8,shortname=mixed,utf8,errors=remount-ro name=primary state=mounted
*-volume:1
description: EXT4 volume
vendor: Linux
physical id: 2
bus info: scsi@0:0.0.0,2
logical name: /dev/sda2
logical name: /imgpart
version: 1.0
serial: 112e9cbe-9047-4a11-9f8d-ded784ddc83b
capabilities: journaled extended_attributes large_files huge_files dir_nlink recover extents ext4 ext2 initialized
configuration: created=2019-07-26 16:51:10 filesystem=ext4 label=volumioimg lastmountpoint=/mnt/imgpart modified=2019-08-03 06:57:41 mount.fstype=ext4 mount.options=rw,relatime,stripe=1024,data=ordered mounted=2019-08-03 06:57:41 name=primary state=mounted
*-volume:2
vendor: Linux
physical id: 3
bus info: scsi@0:0.0.0,3
logical name: /dev/sda3
logical name: /mnt/ext
version: 1.0
serial: f55d2f50-5512-4287-adcf-99d73db50e4a
capacity: 108GiB
configuration: created=2019-07-26 16:51:11 filesystem=ext4 label=volumio_data lastmountpoint=/mnt/ext/union modified=2019-08-03 06:31:25 mount.fstype=ext4 mount.options=rw,relatime,stripe=1024,data=ordered mounted=2019-08-03 06:31:25 name=primary state=mounted
SYSTEM-ANALYZE Result
25.318s mpd.service
23.913s nmbd.service
23.885s winbind.service
23.148s wireless.service
23.136s samba-ad-dc.service
21.194s networking.service
10.228s transmission-daemon.service
10.048s ssh.service
9.706s avahi-daemon.service
5.337s systemd-logind.service
5.242s alsa-restore.service
5.215s openvpn.service
5.206s rc-local.service
5.200s minissdpd.service
5.191s ntp.service
5.190s loadcpufreq.service
5.189s ifplugd.service
5.189s hostapd.service
5.189s dhcpcd.service
4.393s cpufrequtils.service
3.376s nfs-common.service
1.587s plymouth-start.service
1.336s smbd.service
517ms user@1000.service
243ms cd.service
167ms dev-hugepages.mount
167ms kmod-static-nodes.service
166ms dev-mqueue.mount
164ms sys-kernel-debug.mount
154ms rpcbind.service
122ms systemd-tmpfiles-setup-dev.service
119ms xbindkeysrc.service
95ms systemd-user-sessions.service
86ms udisks.service
67ms systemd-udev-trigger.service
64ms polkitd.service
60ms systemd-update-utmp.service
51ms systemd-fsck@dev-disk-by\x2duuid-F7E8\x2d8F97.service
46ms systemd-sysctl.service
36ms systemd-modules-load.service
19ms systemd-random-seed.service
17ms boot.mount
15ms plymouth-quit.service
14ms systemd-udevd.service
14ms sys-fs-fuse-connections.mount
13ms plymouth-read-write.service
13ms systemd-remount-fs.service
12ms systemd-tmpfiles-setup.service
9ms udev-finish.service
8ms console-setup.service
7ms keyboard-setup.service
7ms systemd-update-utmp-runlevel.service
7ms systemd-tmpfiles-clean.service
6ms plymouth-quit-wait.service
6ms var-spool-cups-tmp.mount
6ms systemd-journal-flush.service
5ms tmp.mount
3ms var-log.mount
3ms var-spool-cups.mount
Will we need to change the kernel? Possibly how do I do it? I haven’t found update grub
Help me, please, I’m without music
