Flashed latest bootloader, different card, different versions, no avail?
Is the RPi4 1gb incompatible?
You flashed the file “Volumio-3.396-2022-12-04-pi.img” to the SD using Raspbery Pi Imager
The final check gave no errors
And you have removed any USB storage from the rPi before booting.
If all questions are yes, can you flash raspbian to the SD and try to boot that one. If that goes succesfull, type the following in the prompt and post the results: cat /proc/device-tree/model
Yes to all the above.
I have been using Volumio in various incarnations, for well over a year without issue on other RPi variants.
This RPi4 1gb will boot Raspi OS, but not Volumio
Will reload and get back to you with the results of " `cat /proc/device-tree/model"
Downloaded a fresh iso of V 3.396, used Balena Etcher instead of RP imager, and it has booted to default page for setup.
System information plugin shows:
System Information
OS info
Version of Volumio: 3.396
Hostname: hidden
Kernel: 5.10.92-v7l+
Governor: performance
Uptime: 0 days, 0 Hrs, 2 Minutes, 0 Seconds
Audio info
Hw audio configured: Headphones
Mixer type: Hardware
Number of channels: 8
Board info
Model: Raspberry Pi 4 Model B Rev 1.5
Version: a03115
Firmware Version: Jan 20 2022 13:56:48 - bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
CPU info
Brand: BCM2711
Speed: 1.5Ghz
Number of cores: 4
Physical cores: 4
Average load: 26%
Temperature: 43°C
Memory info
Memory: 988832 Ko
Free: 472960 Ko
Used: 515872 Ko
Storage info
INTERNAL storage - Size: 26309Mo
Used: 18Mo
Available for storage: 24930Mo (95%)
Ok, weird. You’re the first that has issues with Raspberry Pi Imager. These kind of behaviors we have only seen with Balena.
At least your rpi is on rev1.5. (Volumio had to rebuild the kernel with the change from 1.4 to 1.5, hence my question)
So your good to go. Have fune.
