Volumio with Roland UA-S10 interface with 1bit option
Good morning,
I use Volumio with Roland UA-S10 interface. It works great, except for one option. When I use the button, the program locks up. I have to do a restart to get it working again.
I suppose it is the 1bit option
Can you please make this option work?
Tom
sorry the only supported systems are windows and mac. there are no linux drivers.
Please post a log so we can check which drivers have been loaded by the kernel.
The UA-S10 has not been added to the Linux kernel by Roland, so i expect the kernel loaded a different driver causing this behavior. If Roland doesn’t provide drivers there is not much Volumio can do.
Maybe this logs can help with something but i understand it is hard to fix it.
Thank You for fast answer,
Kind Regards
Tom
We need a full log, this partial copy doesn;t tell us a thing. Just following the instructions I’ve posted. Nowhere I mentioned to enable a live log.
Sent
Thank you for help.
reference is GDSC-2590
