Volumio with Hifiberry Amp100 AND RPI 7" Touchscreen
Hi out there,
I just got the “Hifiberry AMP100” running with Voulumio.
This will probably be even easier in the future… :wink:
Question:
Does anyone know the pin assignment for the connection between RPI 3 B+ and the Hifiberry AMP100?
(Currently I’ve just plugged it in as described by Hifiberry, because I couldn’t find any more information on the internet)
My Idea:
With the contact assignment, I might also be able to get the 7" touchscreen from RPI to work with the AMP100. I would then even supply both (RPI with touch screen) and AMP100 separately…
(Switched on and of by the nice Audiophonics solution)
Thank you for your replies in advance
Best regards
Klaus
I´ve just fount some description at hifiberry see link:
https://www.hifiberry.com/docs/hardware/gpio-usage-of-hifiberry-boards/
I’ll ceep you informed about my “device” with AMp100 and Touchscreen…
kind regards
Klaus
