Hello, if I subscribe to virtuoso offer to I get the plugin for room correction bases on BruteFir?
Thanks for the answer
Envoyé de mon Mi MIX 3 en utilisant Tapatalk
hi!
The plugin is available for all. It is not (yet) an official plugin and to install it you have to have a look here : https://github.com/balbuze/volumio-plugins/tree/master/plugins/audio_interface/brutefir3
let me know if you need some help
Hi Balbuze,
Than you for the answer, I am going to try.
Hope everything is Ok for you despite the virus.
Hi again,
I have installed the plugin, but it doesn’t work properly. I am running the latest version of Volumio 2.729 on a pi3B. It is connected to a allo digiOne hat with a coax outpout to the dac.
In the settings I have currently allo “digiOne through BruteFir”
When I start playing the music, the player remains stuck.
If I disable the plugin and restart Volumio it works perfectly.
Any idea?
Have you tried to just enable the plugin, the reboot?
Yes, now the player works, I can see it but the re is no sound.
Should I change something in BruteFir settings!
try to change output format
Hi again Balbuze,
Sorry for bothering, but so far the plugin doesn’t work.
hi!
Some user reports it to work with Allo Digione. Just set output to Factory_S24_4LE.
Do not touch mixer or i2s setting once the plugin is enabled (even if it appears as none).
by default, filters are set to “none”. The sound is not modified. You can choose demo filters to test. (don’t forget to apply
Hi Balbuze,
I am still struggling with the DRC plugin [emoji37]
First I have moved to a ( more powerfull) raspberry pi3b+, without success.
I have also tried the output setting using"
Factory_S24_4LE" : the player works but I have no sound, or to be more specific, no output signal from the allodigione.
I have been trying systematically all the output settings in the scrolling list: no sound.
As usual when I desactivate the plugin Volumio runs like a charm.
Any clue?
please, let’s continue this on the dedicated thread : volumio2-and-brutefir-t4151-460.html
thanks!
