Primo Superstar
Weird new behavior. Everything is fine in the album view. Select and play works. But in the moment I switch to artist view, volumio stops playback and restarts. Any idea what’s going wrong?
Thanks Stephen
Hi Stephen,
please don’t use such versions: they are test builds not meant for regular users.
Please
- Try to reproduce the crash, then send a log:
Sending logs for troubleshooting - Volumio Documentation - Disable TEST MODE, so you will not get other unstable updates
http://logs.volumio.org/volumio/Jz5sMSv.html
Thank you.
Thanks, this had nothing to do with the update. Rather a temporary glitch in the metadata service which has just been solved. thanks for reporting it
You´re welcome
