My Primo 2 stopped while playing a track. I tried many options in the app, without result. Reloading the Android app didn’t help. Factory reset from the UI didn’t work either, the LED stays green now. Reloading factory settings from a USB stick gives the same result: the LED stays green forever.
That’s what I intended to do. But first, for the last time, I tried this morning a factory reset with the USB stick. And yes! It works again! This is at least the 8th time within a year that the Primo lost its settings. Unlike now the settings were easy to restore then. Is this ofter happening? A bad flash memory maybe? Is this the reason why the Primo is not sold in the Netherlands any more?
But it plays again now. And every time I hear it I fall in love with it. It sounds superb! Until it fails again…
Thanks for your help. I might need it again in the future.
Ah, I see you appointed a Dutch importer meanwhile.
I tried to open a support ticket, but I cannot fill it in completely. Primo does not react on my request to send a log. Can I go around that log address in any way? And what’s the difference between Premium and Virtuoso?
