Hi
New user, very impressed with volumio.
What is your current setup (pi1-3, udoo, single/multiple devices, fully hardware device with buttons, touchscreen control, remote webui or mobile, etc)
Currently - Original Pi (256MB & no holes in PCB) some cheap USB device with optical out (48KHz max).
Planned - Pi 3+ Allo DigiOne
Web UI and Android app on tablet.
What are your needs for music discovery (how big is your library, how do you search, do you use/build playlists, do you use streaming/other services, etc),
NAS using DNLA (smb wouldnāt work). Currently have a couple of hundred albums loaded.
I also use web radio a lot (1 web radio channel & 1 shoutcast channel at present) Also occasional youtube addon use
What are your needs for music Playback (what are you doing while listening, what info is important to see, etc.)
Sometimes itās running while Iām using the PC, sometimes Iām only listening (Android app)
How do you maintain and share your music (how do you manage your library, how many do you have, how do you share it, ā¦).
Files ripped with asunder and added to NAS.
I usually search play by album.
For last, I would also like to suggest features you would like to see and especially those you frequently use on other players/platforms, considerations you deem important or specific worries you might have.
If you have concrete examples and links those are useful too.
I would like the ability to add items to the main browse page. e.g. albums folder of my NAS, radio stations.
I would also like it if the play screen artwork display used available album or artist art when it isnāt embedded in the file.
And similarly if album artwork is missing, use embedded art or artist.
Also automatic pause on incoming calls, when using the android tablet (itās a phone too) and the ability to play songs on the android device.
A sorting option showing all albums sorted by artist then by name in one level would be nice too.
even harder with black background
but it confusing once you are using new one
