I am using volumio 2.916 on pc. When clicking on ‘check for system updates’ in settings, I get the message: ‘you are already using the latest version’. Should I do a total reinstallation of Volumio or is there an easier solution? Thanks Luc VdB
thanks gkkpch for this. I tried this but volumio is on my harddisk. When I reboot, volumio always boots again from my hardisk. I don’t seem to get it started from the newly flashed USB drive.
