Volumio unplugged
I had a problem with the installation of Volumio and I did not see volumio on the network, I was obliged to disconnect it to the plug, do you think it is serious?
I was able to make an update it worked, but it damaged?
Thank you
It’s pretty resilient, you are probably ok :slight_smile:
Thank you because sometimes I read that by unplugging it damaged the data and the SD card but I was not sure
